Aidan's SCCA Stock Class Autocross Build (EFR 6758/VVT 1.9L) - Page 3 - ClubRoadster.net
Old 08-18-2016, 08:13 PM   #61 (permalink)
oregonmon's Avatar
Default Re: Aidan's SCCA Stock Class Autocross Build (EFR 6758/VVT 1.9L)
Damn, those meaty RS3s though.
Old 08-18-2016, 08:13 PM   #62 (permalink)
oregonmon's Avatar
Seriously, that trailer it superb.
Old 08-18-2016, 08:18 PM   #63 (permalink)
Official Armchair Racer
stormin'norman's Avatar
Are you making the trip to Nebraska for nationals? It's like 20 hours each way but you get three runs or something.
Old 08-18-2016, 08:19 PM   #64 (permalink)
Lonely White Girl
aidandj's Avatar
Yeah dood. This trailer carries all my gear and tires so I can get there.
I'm hoping to take the win in Ez Street.
1990
1972
- My true love
aidandj is offline   Reply With Quote Quick reply to this message
Old 08-18-2016, 09:17 PM   #65 (permalink)
oregonmon's Avatar
Oh damn, I lol'd at EZ street.
Old 08-18-2016, 11:56 PM   #66 (permalink)
chiprez's Avatar
Haha where's Alex to chime in with his wealth of autoX knowledge.
chiprez is offline   Reply With Quote Quick reply to this message
Old 08-19-2016, 12:22 AM   #67 (permalink)
Zing Master
Sploinkin's Avatar
He's prepping for Nebraska...
2016 Meteor Gray Mica Club
Old 08-19-2016, 12:22 AM   #68 (permalink)
Is there a build thread for your Ford?
TBH I'd rather read about Dana 44's and Flowmaster Super 40's than you cleaning house at the Lincoln nationals.
Old 08-19-2016, 12:28 AM   #69 (permalink)
Lonely White Girl
aidandj's Avatar
There is one somewhere. Dana 44s are way to small. It will end up on 60s. I don't have the cash or room for that project right now. Start me a go fund me.
Old 08-19-2016, 12:34 AM   #70 (permalink)
Well if you find it link me. Cool rig. I still remember when you first rolled up to snag some brakes. Luke and I thought you were someone else and lost.
Old 08-19-2016, 12:37 AM   #71 (permalink)
Lonely White Girl
aidandj's Avatar
It's just me shooting shit and talking about what to do. The body is going on a 7.3 power stroke frame. I have a donor truck sitting in hood river but don't have the cash to do it the way I want (frame off resto). Hailey has said that she will fund it eventually. I need a real shop first.
Old 08-19-2016, 12:12 PM   #72 (permalink)
Lonely White Girl
aidandj's Avatar
Picked up a couple sets of bungs off ebay. The 1/8 NPT bungs are for EGT probes. And the aluminum 10an bungs are for valve cover fittings. Which will run to catch cans.
1990
1972
- My true love
Old 08-19-2016, 05:15 PM   #73 (permalink)
Lonely White Girl
aidandj's Avatar
And a preview of what the ports on the flange will look like
1990
1972
- My true love
Old 08-19-2016, 09:42 PM   #74 (permalink)
Lonely White Girl
aidandj's Avatar
Traded these for a slice of pizza today
1990
1972
- My true love
Old 08-19-2016, 11:07 PM   #75 (permalink)
Lonely White Girl
aidandj's Avatar
Interesting bit of trivia
0-93 gas tanks are smaller than 94-97. I knew the NB gas tank was bigger but the NA6 fuel pump sits about 2 inches higher than the NA8. So I had to modify my mounting.
I also ordered PTFE heat shrink to hopefully keep it together.
1990
1972
- My true love
Old 08-20-2016, 01:50 PM   #76 (permalink)
Lonely White Girl
aidandj's Avatar
Working on my block ventilation plan right now. Ordered some 10AN bungs. Going to do 10AN on the exhaust side. With drilled out passages. And to a catch can. Intake side will go to home depot catch can with PCB valve.
Before the motor goes to get worked on I'm going to drill and tap the whole that Bob used for a block vent. Not sure I'm gonna use it, but I'll cap it and has it as a backup.
http://www.miataturbo.net/race-prep-...e2/#post946072
Old 08-21-2016, 01:11 PM   #77 (permalink)
Lonely White Girl
aidandj's Avatar
Picked up a set of 5/16 tube nuts and sleeves, along with 5AN-6AN adapters to connect from hardline to AN in the engine bay.
Aeroquip FBM3679 -05 steel tube sleeve (2 per package)
Aeroquip FBM3571 -05 steel tube nut
Aeroquip FBM2755 -06/-05 steel male reducing union
Old 08-25-2016, 04:51 PM   #78 (permalink)
Lonely White Girl
aidandj's Avatar
The EFR turbine housing is held on by 4 bolts with clamps. They have a 10ft/lb torque spec, and theoretically shouldn't come loose.
I break things that shouldn't be broken....so I decided to safety wire them.
Was going to try and get a jig for drilling bolts until I came across this awesome site: http://drilledheadbolts.com/products...16mm-10-pieces
Predrilled stainless bolts, in my size. Ordered a set of 10 and split them.
Turbine housing stay on turbo, so turbine wheel stay intact.
1990
1972
- My true love
Old 08-26-2016, 03:54 PM   #79 (permalink)
Lonely White Girl
aidandj's Avatar
Shoutout to AdoboMiata. Snagged his SPM damper.
Need to get a 36-2 trigger wheel and were good to go.
1990
1972
- My true love
Old 08-26-2016, 06:00 PM   #80 (permalink)
oregonmon's Avatar
Grabbed your spare rack today, I can try to drop it off this weekend, maybe Saturday night.
Old 08-26-2016, 06:01 PM   #81 (permalink)
Lonely White Girl
aidandj's Avatar
Cool. Can you install it too?
1990
1972
- My true love
Old 09-01-2016, 03:49 PM   #82 (permalink)
Lonely White Girl
aidandj's Avatar
Supermiata damper showed up today. A little beat up. But perfectly functional.
1990
1972
- My true love
Old 09-01-2016, 04:23 PM   #83 (permalink)
Did Ray Charles install that thing? Fak
Maybe hit it with some powder?
Old 09-01-2016, 04:24 PM   #84 (permalink)
Lonely White Girl
aidandj's Avatar
Its called character.
Just wait a year or 2 and yours will look like it too.
1990
1972
- My true love
Old 09-01-2016, 04:27 PM   #85 (permalink)
Looks like someone took it ice blocking.
Old 09-01-2016, 04:28 PM   #86 (permalink)
Lonely White Girl
aidandj's Avatar
I'm gonna start sprinkling salt on your pulley every track day.
1990
1972
- My true love
Old 09-01-2016, 04:28 PM   #87 (permalink)
notbenh's Avatar
SaltyPulley
notbenh is offline   Reply With Quote Quick reply to this message
Old 09-01-2016, 04:31 PM   #88 (permalink)
Sure. I'll just replace it with a Unorthodox Racing crank pulley. Same thing anyways.
Old 09-01-2016, 04:32 PM   #89 (permalink)
Lonely White Girl
aidandj's Avatar
As long as it comes with a coupon for a free engine rebuild.
1990
1972
- My true love
Old 09-01-2016, 04:34 PM   #90 (permalink)
I'll just keep a shrine burning in the passenger seat. My stead is #blessed
