#1 (permalink) |
Speed Racer
Ok, so I feel I have made enough progress in buying parts and starting to modify my car that I can start a build thread
My car is a 1991 BRG that originally had all options but an auto tranny. Parts acquired thus far: -LS6 engine with 9,000 miles out of an 01 Corvette Z06, no A/C or PS (installed) -V8 Roadsters subframe mounting kit (includes tubular subframe, engine mounts, tranny crossmember, and frame rail braces) (installed) -T56 transmission out of a 1999 Trans Am (6 speed), with B&M short shifter and skip-shift eliminator (installed) -Spec Stage 2 clutch (installed) -Drive by Wire throttle pedal from a 97-04 Vette (installed) -Walbro 255 (installed) -Vette Filter/Regulator (installed) -AN fittings and stainless lines for fuel (installed) -New Clutch Master Cylinder, bleed line (installed) -CTS Diff (05, 54k, 3.42 gears and LSD) and diff vent (installed) -V8R Stage 1 Mounting kit (installed) -Refreshed Hubs/Wheel bearings courtesy of Planet Miata (installed) -Sport brakes (installed) -OEM engine harness converted to standalone by Speartech (installed) -TAC box to DBW pedal harness (Speartech also) (installed) -V8R screw-on oil filter oil pan (installed) -FM V8 Swap Front Sway Bar (installed) -FM Cross Flow Radiator (installed) -Mezeire Race Electric Water Pump (installed) -Racing Beat Endlinks F/R (installed) -949Racing 6UL's; 15x9 +36 with 225/45/15 Toyo R1Rs (sold), now 15x10 +25 6ULs -ECU reflash (delete VATS and 2 of the 4 o2 sensors it is looking for, base map for cam)(done/installed) -o2 sensors (acquired) -Summit Digital Gauge Panel (SUM-800600) (acquired) -Custom carbon "smooth" half dash modeled after GHO race dash (in progress) -Flyin Miata headers (ceramic coated by local shop) (installed) -6.0L Starter wrapped in starter blanket (installed) -MSM Brake Master Cylinder and Booster (installed) Parts that I still need for the swap: Exhaust -Exhaust system (Fabricated, ready for coating) Other -Seats -Cage Progress pics ![]() ![]() ![]() ![]() Project goals: -Shaved, tucked, and stitch welded bay (done) -2200-2300lb curb weight (no A/C, PS, Cruise, ABS, heater) Random notes: -OEM Miata wiring harness with plugs for all options weighed 17lbs. |
_Jess_ 1991 White Mazda Miata DD 1991 BRG Mazda Miata ![]() LS6 swap coming soon http://clubroadster.net/vb_forum/89-roadster-projects/33687-91-brg-ls6-build.html Last edited by XCLR8TN; 04-14-2013 at 10:20 PM. |
#6 (permalink) |
Speed Racer
Dang that was more response than I expected lol. Thanks for the kind words everyone! I got a new better-paying job so hopefully I can start buying more parts soon
_Jess_ 1991 White Mazda Miata DD 1991 BRG Mazda Miata ![]() LS6 swap coming soon http://clubroadster.net/vb_forum/showthread.php?t=33687 |
#8 (permalink) |
bad mother f......
Coolest girl on the board? I think so! cant wait to see how this one turns out.
I'm flipping burgers overtime so I can get the sportmaxxxx of my dreams.
#11 (permalink) |
Official Armchair Racer
wow. Good luck! Keep the pictures coming
![]() "I think I'll go buy one of those large foam hands you see at sporting events and zip tie it to my left mirror in a permanent point-by position." -Rich Cohn Lee |
#12 (permalink) | ||
Part number for the headers: Sanderson Headers LS150M (Price is $350 I think...) http://enthuzacar.com/ makes the bolt on exhaust. Its true dual/stainless steel/under $1k last time I called them...Stainless is more Quote:
I can keep going lol Also, call FM and buy the heat shields for the motor mounts ASAP!!! They are $34.95 for the pair and will protect your motor mounts from melting. Mine started to melt so I need to drop the subframe again. I guess FM had this issue on a few cars as well. |
#13 (permalink) |
I'm also building a V8R, LS2,T56,Getrag 3:43, one area to watch is the relocation of the raditor. It needs to move forward several inches, along with the front sway bar. Also pound some extra speedometer connector clearance in the tunnel. You will be glad you did later. It looks great. Good luck.
#16 (permalink) |
Honey-D n' 15g
OH BOY!!!
This has been on of the most memorable cars on the board and now its getting a proper engine, I'm so excited for this! Subscribed. p.s. i'm glad i know about that Enthuza exhaust now |
#17 (permalink) | ||||
Speed Racer
I have a little bit of a surprise planned for the exhaust, but it's good to know about the headers AND heat shields! Quote:
I'll see how the rad works out, since I won't have A/C I figured if I needed to I could use the extra space in front Quote:
I think the hardest part of all this is keeping track of the people I encounter along the way who want to see the car when it's done, lol. |
#19 (permalink) |
glad someone else is tackling a V8 swap themselves, fk Flyin Miata and their outrageous prices
the more common this becomes the cheaper we can buy hand me down V8 Miatas lol |
#21 (permalink) |
Faster, faster, faster, until the thrill of speed overcomes the fear of death - Hunter S Thompson '97 BRG/Tan, R-lips, RyokuRob tow hooks, HT, DIY visor blanks, Hawk HPS, FM sways, 949 endlinks, 949 brake lines, KG works dash panel and spoiler... |
#25 (permalink) |
Seeing this build thread pop up makes me feel all warm and fuzzy inside. Thanks jess
3rd try: 1994 M Ed. M1HDHC, OBX header, Koni Yellow/FM springs, JR sways 2nd Miata: 1994 JRSC: hated and sold that POS 1st Miata: 1992 base: owned and daily drove 3.5yrs: traded off and miss it |
#26 (permalink) |
That clutch rating is terrifying.
You're probably left with a pretty narrow range of offsets for 10"s. Probably +23 to +29, just based on your current wheels and how 9" 6ULs clear on the inside. I'm assuming 225s? |
#29 (permalink) |
Hardparker Extraordinaire
Can't wait to see this completed....and god do I need a better paying job so I can do something like this
'01 IS300 the fun "adult/family" car ![]() SOLD |
#30 (permalink) |
I have talked previously with Steve at V8R who said that 3:73 gearing will fry tires and the 3:42, corrected ratio, gearing is better suited for the Miata street/autocross applications. Some peope even recommend 3:23. Others with conversions done and used on he street seem to indicate that 3:42 still is a lot of gearing for tire size that will fit a NA miata w/o wheel flares 225/50/15 tires is about Max for a NA.
