Doward's Jack of all, Master of None Build - Page 3 - ClubRoadster.net
Old 02-09-2013, 08:26 AM   #61 (permalink)
doward's Avatar
Time is becoming an issue. Motor is going in this weekend, goal is have it running Sunday and then to drive it home some time next week. We are building an Exocet for a local guy and having a loft built in the barn, opposite the lift. Then we need to get our autoX car(s) sorted. All before mid April-ish? 0.o
NB spindles gave me another 5mm offset bump, rear looks fantastic! We'll see how the front fits once an engine/tranny go in.
I also stumbled across a totaled 94R parts car. This thing has the entire Racing Beat catalog on it. Header, cat, Power Pulse, springs, Konis, sways, links, blocks and brace kit, Simpson Design cowl hood..
So I threw the hood on real quick to see what it looked like.
Looks like it is save able.
-Dan @
doward is offline   Reply With Quote Quick reply to this message
Old 02-10-2013, 01:29 AM   #62 (permalink)
Stock's Avatar
Default Re: Doward's Jack of all, Master of None Build
Love this build. <3
Instagram -TF_Tyler
- Parted out
- Sold
Stock is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 12:29 PM   #63 (permalink)
doward's Avatar
Originally Posted by Stock View Post
Love this build. <3
Thanks!
I picked up my flywheel from the machine shop today. Just need to grab some break in oil on the way home and finish it all up this weekend!
-Dan @
Old 02-16-2013, 12:00 PM   #64 (permalink)
cw3263's Avatar
love this, awesome content
cw3263 is offline   Reply With Quote Quick reply to this message
Old 02-16-2013, 01:07 PM   #65 (permalink)
Ethaniscool's Avatar
SOOOO awesome. Keep up the good work
Ethaniscool is offline   Reply With Quote Quick reply to this message
Old 02-18-2013, 11:33 PM   #66 (permalink)
doward's Avatar
Thanks fellas!
Got a little update to paste in here...
-Dan @
Old 02-18-2013, 11:35 PM   #67 (permalink)
doward's Avatar
So I spent the majority of my day Saturday trying to track down this bad boy..
Turns out the "MERICUH!! machine shop I used for the flywheel resurface tapped the clutch cover threads to something OTHER than correct. The m8x1.00 thread pitch is not commonly found in the metric tap & die kits you buy. The tap was a special order at the 3 closest Sears locations, mid week before I might see one. Luckily there are mom & pap hardware stores in this great town like Roush Hardware in Westerville who carry awesome stuff like this!
SO, Sunday morning I got a good forearm workout in...
At this point, there was no hope in firing the thing up that day, so I slowed down a bit and cleaned all the remaining hardware on the wire wheel:
NEAT DETAIL!
While I was under there I swapped in this body plug from that wrecked R car, this is the drain from the a/c unit under the dash. My car is now pretty much a 94 M Edition/R pkg/NB...
After the trans, ppf, '02 driveshaft went in I snapped this cool shot looking through the bumper mouth. By the way, you're welcome for the stellar photo quality!
Ultimately, I left it needing a radiator, fluids, WBO2, and start-up!!
Catch can is temporary, please disregard. Ideally i'll swap back in a squaretop or the 99 VICS manifold, run a dual inlet catch can and vent to a slash cut in the exhaust.
-Dan @
Old 02-21-2013, 05:01 PM   #68 (permalink)
doward's Avatar
not much to post, except to say IT FUCKING RUNS!!
Got some fluids, apparently this Brad Penn break in oil is hot shit. Few different shops recommended it after I bought the Rotella and Lucas zinc additive.
Pulled the ign fuse, cranked it couple times, plugged it back in and...
-Dan @
Old 02-24-2013, 08:19 PM   #69 (permalink)
doward's Avatar
Light at the end of the tunnel! Put 30 or so miles on it today for shakedown/ break-in. Typical drips and drops from fresh brake unions, wore the rust off the rotors, tightened a rad hose, etc. It's a weird feeling driving around in something that I've completely rebuilt or replaced all the mechanical components of in the last few months.
There is a hearty layer of dirt and dust on the thing but it still looked pretty cool in daylight for the first time since November-ish?
-Dan @
Old 02-24-2013, 08:53 PM   #70 (permalink)
here for farts
very cool man.how did the power feel?
rysmiata92 is offline   Reply With Quote Quick reply to this message
Old 02-24-2013, 08:58 PM   #71 (permalink)
doward's Avatar
I haven't been over 5k or ~50% throttle but it feels pretty good. Way stronger than the junkyard 99 motor I had in it last year. The car is probably 50-60lbs lighter since the last built motor dynoed 142/135 too.
-Dan @
Old 03-09-2013, 07:15 PM   #72 (permalink)
doward's Avatar
Coming off 8-10" of snow Thursday night, today was 59* and sunny. Ridiculous.
We had planned on getting the garage ready for the loft install. This required the relocation of half the stuff in there.
Before, with my car.
After, looking at the same corner
The loft will be all steel. Approximately 20x25 with the stairs leading up right in front of the entry door.
Spent the better part of 6 hours doing that...
-Dan @
Old 03-09-2013, 07:20 PM   #73 (permalink)
doward's Avatar
With the barn a mess, I finally had to get my car home.
Stopped off to see some friends with the glorious layer of dirt still intact!
This thing was absolutely filthy. It doesn't even get that dirty during a rainy track weekend. Spent the rest of the day cleaning.
-Dan @
Old 03-10-2013, 01:10 AM   #74 (permalink)
Stock's Avatar
One of my favorite cars on CR. Love it.
Instagram -TF_Tyler
- Parted out
- Sold
Old 03-10-2013, 08:20 AM   #75 (permalink)
doward's Avatar
There are some amazing builds on here. Thank you!
-Dan @
Old 03-10-2013, 10:18 AM   #76 (permalink)
Joeyz31's Avatar
Motor looks great dude. I bet it pulls. When's the first track day?
Red R pkg prepared for the track:
Joeyz31 is offline   Reply With Quote Quick reply to this message
Old 03-10-2013, 05:40 PM   #77 (permalink)
doward's Avatar
The start of something cool for the racecar:
The back of the face is not flush, so I couldn't reverse mount them even if I wanted to...
-Dan @
Old 03-11-2013, 03:53 PM   #78 (permalink)
meehata's Avatar
good stuff Doward!
meehata is offline   Reply With Quote Quick reply to this message
Old 03-11-2013, 05:00 PM   #79 (permalink)
Stock's Avatar
I prefer driver's cars to hella-swag-yolo builds and I'm sure this thing is a blast with the new motor setup. I'm living vicariously through you since my build slowed down.
Instagram -TF_Tyler
- Parted out
- Sold
Old 03-14-2013, 02:12 PM   #80 (permalink)
doward's Avatar
Dropped the centers and a protege valve cover off at the blasters today. I had some bungs welded to the vc, and plug welded the stock rear port. Wheels will stay fairly neutral as they'll be used on multiple cars. Options for the refinish are; a normal Panasport silver, matte bronze, or gloss white. Orange is hanging around in my mind as well. I have tons of the orange reflective vinyl left over from the numbers I cut for the black car...
Input?
-Dan @
Old 03-14-2013, 03:11 PM   #81 (permalink)
Stock's Avatar
Silver.
Instagram -TF_Tyler
- Parted out
- Sold
Old 03-14-2013, 05:25 PM   #82 (permalink)
'Bout dat life
reversecaoboy's Avatar
Silver. It's been ingrained in my mind you don't mess with panasports.
99 NB
reversecaoboy is offline   Reply With Quote Quick reply to this message
Old 03-14-2013, 09:22 PM   #83 (permalink)
doward's Avatar
Hah! That's exactly why I want to mess with them! These are beat to shit. We'll see how they look after blasting.
-Dan @
Old 03-15-2013, 06:16 PM   #84 (permalink)
doward's Avatar
First full tank for the fresh motor.
Still needs aligned and corner weighted, pay no mind to the reverse rake. ;p
Hardtop is off, I'm brainstorming options to seal the lexan. Also contemplating pulling the softtop. New windshield going in soon, first event in April.
-Dan @
Old 03-16-2013, 06:29 AM   #85 (permalink)
Scrappy Jack's Avatar
Gunmetal or a darker grey/graphite for the wheels, possibly leaving the lips polished?
Originally Posted by revlimiter
Those who are always worried about bottom dollar or how much more they're spending than the car is worth will never build anything great. They'll rarely build anything that even meets their expectations.
Scrappy Jack is offline   Reply With Quote Quick reply to this message
Old 03-16-2013, 10:06 AM   #86 (permalink)
doward's Avatar
Lips will definitely stay polished.
In fact, I killed an hour cleaning two of them up this morning.
This is what I'm starting with:
30 minutes with some mothers mag&aluminum and a rag:
Im not sure if they'll get much more attention than this. Several nicks, chips, and scratches in all four lips.
-Dan @
Old 03-16-2013, 10:32 AM   #87 (permalink)
scradley's Avatar
such a good build. keep it up!
92 LS build>>
scradley is offline   Reply With Quote Quick reply to this message
Old 03-17-2013, 09:19 PM   #88 (permalink)
doward's Avatar
36* today. I ain't care. I need to rack up at least 500 miles before the track day April 18/19. ~120/500
-Dan @
Old 03-26-2013, 08:15 PM   #89 (permalink)
doward's Avatar
We picked up a set of not-new-but-never-used Hankook c71 softies for the Panas. 225/45/13. Should be plenty for my codriver to learn rcomps.
-Dan @
Old 03-26-2013, 09:43 PM   #90 (permalink)
doward's Avatar
Got the faces back from blasting. They look cool as heck in the raw blasted texture. So I'm just gonna throw em together. It they get nasty, greasy, brake dusty in one season, then I'll re blast and paint em next winter.
Lip before
Lip after hand polishing
Just marry em up
-Dan @
