Doward's Jack of all, Master of None Build - ClubRoadster.net
Old 07-11-2010, 11:00 PM   #1 (permalink)
doward's Avatar
Default Doward's Jack of all, Master of None Build
Its been almost exactly 1 year from when i popped my old motor. Ive since moved into a house and switched jobs, so progress has been really really slow. Heres a few pics i have laying around, new motor shots and some new wheel shots:
Motor Specs:
9:1 CP pistons
Eagle rods
Cometic gaskets
ARP everywhere
New OEM water/oil pumps
New OEM timing belt
AEM EMS w/GM 3bar map, AIT sensor in monsterflow intake pipe, MAF delete
Dyno of build: Mods include bottom end listed above with a bone stock 99 head, stock cam timing, miataroadster intake mani gasket, custom throttlebody gasket, monsterflow intake, maf delete, aem dryflow filter, obx header ceramiced and wrapped, used high-flow cat, roadstersport race exhaust:
New Konig Bbombs 15x7.5 et0 w/ 195/50 RE-11
Im going to use this as my own memory bank as things come up..
Things left on the list:
-Break in new motor
-Retune after break in
-Paint hardtop
-Finish spare polished hood/carbontrix extractor scoop project
-Fix/rewire coolant temp senor/gauge
-Install walboro
-Gather rest of turbo parts
-fix wastegate on used mazdaspeed turbo
-source new/larger turbo?
-Build head
-Aftermarket honda B series intake mani
-ExIntake?
-Redo my rushed hackjob of ABS delete
-Remove heater blower/underdash a/c junk/stereo
-Install some sort of thermal barrier on trans tunnel
May add a full mod list later
I went 9:1 on the pistons to allow full flexibilty on FI. I feel like im standing on top of the fence between ITBs and a 949 header, rotrex kit, or turbo. Anyone in central ohio/midwest in general wanna let me test drive their car with such power mods?
Does the power seem right? Wasnt sure what to expect with the 99 head, boltons and AEM.
doward is offline   Reply With Quote Quick reply to this message
Old 07-11-2010, 11:12 PM   #2 (permalink)
Default Re: Doward's Jack of all, Master of None Build
Can't speak to the power output, but you've got a nice build going there! Keep it up!
eddy is offline   Reply With Quote Quick reply to this message
Old 07-11-2010, 11:48 PM   #3 (permalink)
Speed Racer
XCLR8TN's Avatar
Lookin good... did you ever get a driver side fender replacement? Can't tell from those pics.
Wheel fitment looks excellent--how do you like the tires?
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap ...SOON
XCLR8TN is offline   Reply With Quote Quick reply to this message
Old 07-13-2010, 08:35 PM   #4 (permalink)
doward's Avatar
You can see the nasty rip and paint flake in the drivers fender if you look for it, still the same. lol
EDIT for pic:
Tires seem good. cant say much as i was used to the 225/45 R1R and NT01s i ran last time i drove this a year ago. Going down the the 195s is a big change.
Old 07-14-2010, 01:11 PM   #5 (permalink)
Friday's Avatar
Thats a nice bit of power. What has the motor build cost you so far?
Friday is offline   Reply With Quote Quick reply to this message
Old 07-14-2010, 01:43 PM   #6 (permalink)
apexscalpel's Avatar
Those are very strong numbers!
___ ___ ___ _ _ ___ _ _ _ _ _
apexscalpel is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 10:47 PM   #7 (permalink)
doward's Avatar
Started messing with the hood, layed out some tape, took some measurements and got the extractor positioned. Using a Carbontrix 18" scoop. The front edge of the scoop is directly above the back edge of my radiator. That spot puts the actual vent opening almst dead center between radiator and timing belt. Need to get my 949 coolant reroute put on and get rid of the front water neck to route ducting. My car looks super cramped compared to other na's in that area, with the 99 head swap the 99 mani/TB comes farther foward, and my radiator being nearly twice as thick as stock in the other direction.
Also gave the drivers side about 30 minutes with rubbing compound. Hood is just paint stripper and rubbing compound. no sandpaper yet. i fucked up the front portion between the lights with a grinding disc we;ll see if that part sands out..
Old 07-19-2010, 10:58 PM   #8 (permalink)
doward's Avatar
Seems pretty healthy for a lower(stock) compression ratio. Built it with strong intentions to boost it though! With the way things are going, that wont happen till winterish..
More piece of mind and potential than a junkyard bottom end and begi s kit i almost did..
Old 07-19-2010, 11:45 PM   #9 (permalink)
Function > Form
saedrin's Avatar
Power seems correct, go turbo, you'll really thank yourself in the end. You'd want higher CR with ITB's, supercharged you really won't be taking advantage of the built motor, and with a solid turbo you can do whatever you want with it in terms of power goal.
-Zack
Turbo'd/r-comp'd NB1.
E39 M5, Daily.
saedrin is offline   Reply With Quote Quick reply to this message
Old 07-19-2010, 11:52 PM   #10 (permalink)
doward's Avatar
Quick start/rev video we shot. Motor wasnt broken in yet so this is just 5krpm around the 17 second mark. ends around 20 seconds
I LOVE IT!
Old 07-20-2010, 07:06 PM   #11 (permalink)
Herp Derp
Road Pirate's Avatar
Very nice! Car looks good and sounds sick! haha.
Road Pirate is offline   Reply With Quote Quick reply to this message
Old 07-23-2010, 07:59 AM   #12 (permalink)
needs a wingman
chrisnick's Avatar
Looks like SloMo's dyno.
1995R: Gone.
1996 crapbag Base winterbeater
1997 Accord Coupe LX 5-speed autocross beater
chrisnick is offline   Reply With Quote Quick reply to this message
Old 07-25-2010, 10:08 PM   #13 (permalink)
doward's Avatar
One and the same.
Old 09-15-2010, 10:50 PM   #14 (permalink)
doward's Avatar
So I missed most of the season with my local miata club autocross with the rebuild going on. Made it to the first 2 of the last 3 events so far, if that made sense to anyone haha. I made FTD both times, over a couple turbo/supercharged cars on 225/45s, one car has a FFS cold side kit and 225/45/15 hankook c71s! We also have a couple non miatas that run, including a Z06 on race tires and a caterham w/ an ecotec and goodyear race slicks, s2000s, minis etc The car is set up so well, finaly getting a payoff from all the work.
So here are some pics!
Should have more coming soon i hope. These are from 3 weeks ago, just had another last sunday.
Might actually make the last trackday at midohio this year too. Will try and get video in the car for that!
Old 10-28-2010, 07:26 PM   #15 (permalink)
doward's Avatar
Some pics from the drit event last weekend and future progress pics
Blox ITR copy B18 intake mani, ceramic coated. Will be running factory honda b18 throttle body, miata cable.
Photo of ports to show how similar they are to miata ports:
[IMG]http://i20.photobucket.com/albums/b229/DRFTMX5/97343cb7.jpg[/IMG
Old 10-29-2010, 10:26 PM   #16 (permalink)
Corm, I like it.
Dilly's Avatar
Would you have to bore out the inside of the mani at all? Or direct bolt on without any issues?
Dilly is offline   Reply With Quote Quick reply to this message
Old 10-30-2010, 03:10 PM   #17 (permalink)
Closed Shell Syndrome
iRoadster's Avatar
Subscribed for this build. It's nice to see this car is still around.
Good to have you on board the MR forum welcome
There's no "turned into." I've been a nerd for 38 years.
iRoadster is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 12:47 PM   #18 (permalink)
'Bout dat life
reversecaoboy's Avatar
I am quite interested in this manifold setup.
99 NB
reversecaoboy is offline   Reply With Quote Quick reply to this message
Old 10-31-2010, 05:51 PM   #19 (permalink)
doward's Avatar
30+ page thread on miataturbo about it.
Simple version is:
Cut off honda flange/fuel rail mounting crap, mount on mazda flange.
"The idea of this Honda IM is a compromise between an extreme top end IM and the shit stocker while maintaining the integrity of the mt.net community's inherent need to be as cheap as possible."-Braineack
Most, if not all of the guys that have done this are turbo. Im still n/a so it will be fun to see what i get out of it with a mild motor setup.
Old 11-01-2010, 02:55 AM   #20 (permalink)
Corm, I like it.
Dilly's Avatar
I just went through all 21 pages of the Honda IM thread on Miataturbo. Interesting info. Thanks.
Old 11-01-2010, 05:25 PM   #21 (permalink)
doward's Avatar
You should throw one on dilly. Our cars would be even closer related cousins..
Old 11-02-2010, 04:54 AM   #22 (permalink)
Corm, I like it.
Dilly's Avatar
I'll think about it for my future build. I have access to almost everything needed as far as cutting and welding the IM together. So that part should be okay. I'll be keeping an eye on your build to see how yours goes.
Old 11-08-2010, 06:47 PM   #23 (permalink)
doward's Avatar
Finally got some action photos from the last autox and the last drift event!
Old 11-11-2010, 03:25 PM   #24 (permalink)
doward's Avatar
Progress made.
We ended up just filling and redrilling the honda flange instead of cutting and swapping flanges. The 180* nature of the 99 manifold and the VICS chamber made it a little too complicated to do that way.
Looks like i'll have to reroute how the fuel lines come up from the framerail and move whats left of the charcoal canister stuff.
Cant wait to put it back on the dyno
Old 11-12-2010, 02:36 PM   #25 (permalink)
Friday's Avatar
The big shiny manifold looks cool. Those numbers are great for only 9:1, your torque curve is so flat.
Old 11-13-2010, 11:17 PM   #26 (permalink)
skynyrd006's Avatar
Doward, what suspension are you running?
skynyrd006 is offline   Reply With Quote Quick reply to this message
Old 11-14-2010, 04:13 AM   #27 (permalink)
Corm, I like it.
Dilly's Avatar
Stance GR+
^ That took me foreverrrrrr to find. Haha.
Old 11-14-2010, 10:35 AM   #28 (permalink)
skynyrd006's Avatar
Originally Posted by diLLy View Post
Stance GR+
Haha thanks man.
Old 11-16-2010, 10:59 AM   #29 (permalink)
doward's Avatar
Yep, dilly is correct. Stance gr+.
Also have rpkg ends on secret element extended inners on a depowered/gutted steering rack.
Full urethane bushing kit and delrin diff mounts.
TCSportline rucas were in then out, now on a shelf.
RB hollow front sway and nb stock rear sway.
-Dan @
Old 11-16-2010, 11:53 AM   #30 (permalink)
hoangy's Avatar
Badass Thread man, subbed for future updates!
hoangy is offline   Reply With Quote Quick reply to this message
