My NA becomes a track car (Build thread) - Page 2 - ClubRoadster.net
Old 04-20-2011, 01:27 PM   #31 (permalink)
ThePass's Avatar
Default Re: My NA becomes a track car (Build thread)
Originally Posted by TSR85 View Post
Nice build. Im digging the diffuser too!
Quick question, Im kinda liking that dash guage pod, which one is it, or were did you get it from?
Thanks!
It's just the regular black gauge pod by autometer: http://www.autometer.com/cat_mounts.aspx?sid=49
I think I ordered mine from Summit Racing.
edit: I might have misunderstood which gauge pod you meant. If you mean the dual pod in the center of the dash, it's a dual pod for a mustang: http://www.summitracing.com/parts/ATM-10001/
-Ryan
Red '90 Turbo 1.6 - 207whp/208 ft-lbs - track car - Innovation by Blackbird Fabworx
Green 1999 - stock DD
2008 1000RR - 172 rwhp "You live more for 5 minutes going fast on a bike like that, than other people do in all of their life" -Marco Simoncelli
2003 600RR - track bike
ThePass is offline   Reply With Quote
Old 04-20-2011, 01:30 PM   #32 (permalink)
TSR85's Avatar
oh, I meant the dual pod above the eyeball vents.
TSR85 is offline   Reply With Quote
Old 04-20-2011, 10:31 PM   #33 (permalink)
astroboy's Avatar
Glad to see this car is making it to the track. Once you get comfortable with its manners will you add the diffuser to see how much benefit there is to having it? Also has this thing been corner weighted?
astroboy is offline   Reply With Quote
Old 04-20-2011, 10:32 PM   #34 (permalink)
000FWHP's Avatar
wow i am really really really liking that rear side exit exhaust, looks awesome though, keep it up!
000FWHP is offline   Reply With Quote
Old 04-21-2011, 03:07 AM   #35 (permalink)
ThePass's Avatar
As long as I want to stay in Mod class for Miata Challenge (which I do), I can't take any points for rear aero.
Mod is a really interesting class - the current fast cars in it are basically a spec miata on much nicer suspension and tons of grip - 15x9's and NT-01's. However, my car fits in the same class and has significantly more power, same wheels, but less grip (RS-3). Theoretically, these two very different setups might be fairly equal overall.
I'm going to focus on reducing drag with some work on the front for now.
Haven't gotten around to weighing the car..
Old 04-21-2011, 03:46 AM   #36 (permalink)
mrsuave's Avatar
Always wanted to see your car since you live in san diego! car is looking good.
and i like that sticker " Save weight. Drive naked"!
VRGT msm #31!
Originally Posted by winlowe View Post
mrsuave is offline   Reply With Quote
Old 04-24-2011, 06:14 PM   #37 (permalink)
Minute Man aka PC's Avatar
Awesome project!
"Don't mess with the King..."
Minute Man aka PC is offline   Reply With Quote
Old 04-25-2011, 02:45 AM   #38 (permalink)
Bobodahunk's Avatar
i want my miata at the point yours is...its an inspiration
Bobodahunk is offline   Reply With Quote
Old 04-25-2011, 03:26 AM   #39 (permalink)
i am curious about your exhaust reminds me so much of a tvr.
weemanch is offline   Reply With Quote
Old 04-25-2011, 09:49 AM   #40 (permalink)
astroboy's Avatar
Interesting, you should look into getting it cornerweighted to make the most of your setup imo. Nevertheless it is good to see your car competes well against the others.
Old 05-02-2011, 01:05 AM   #41 (permalink)
the_stig's Avatar
Sup Pass, I came over here from your link on mt.net in Pusha's quick disconnect bumper thread. Love the rest of your car even more. Whats the deal on the body kit? Is it all Racing Beat?
the_stig is offline   Reply With Quote
Old 05-02-2011, 01:47 AM   #42 (permalink)
ThePass's Avatar
hey stig, thanks. Actually, the bumper is a Chaser chin molded into an oem bumper, and the sideskirts are chopped and reshaped Wizdom skirts. The rear bumper is... 40% of a stock bumper
The RB sticker is just there from back in the day when I liked stickers and I've got a few parts of theirs on the car..
Old 05-02-2011, 02:23 AM   #43 (permalink)
735e32's Avatar
Looks great!
735e32 is offline   Reply With Quote
Old 05-02-2011, 02:50 AM   #44 (permalink)
XDEEDUBBX's Avatar
very nice car. Keep up the good work! And good luck to you on the track, im very jealous!
Laguna Seca Blue not mariner blue
XDEEDUBBX is offline   Reply With Quote
Old 05-03-2011, 07:07 PM   #45 (permalink)
the_stig's Avatar
For the diffuser, what and how many supports did you use? And did you just have to cut the outer and inner part of the bumper or any frame or unibody?
BEGi S4, GT2860RS, MSPNP, 2.5" catless, 440cc RC's, 15x8 6UL's, H&R springs, racing beat front swaybar = 247rwhp, 9.4 in 1/8, 10-11psi
Old 05-05-2011, 04:02 PM   #46 (permalink)
ThePass's Avatar
Four supports/struts along the rear edge. I cut three brackets for the struts to mount to to out of aluminum angle stock, bolted those to the diffuser, then built the struts from threaded rod, nuts and washers, and aluminum tube. The struts extend through holes in the floor of the trunk. This way, the height of the rear edge of the diffuser is adjustable - just move the nuts on the threaded rod.
At the centerline, I riveted a U-shaped aluminum stock across the diffuser to give it rigidity. This extends past the sides of the diffuser a few inches, and mounts to a stock tab on the rear of the wheel well where the wheel well meets the rear bumper skin.
At the front edge, I riveted an aluminum angle stock width-wise across the diffuser, again for rigidity, and cut/bent two brackets which come off that angle stock and mount to the two lower sway bar bracket bolts.
All together, super light, very very rigid, and doesn't mount to the bumper skin at all. (which is not so secure).
I did sawzall off all of the frame that extends down for the stock tow hooks to mount to. You can see that in the picture on page 1 with the diffuser removed.
A pic is worth 1,000 words:
Closeup of the strut:
Old 05-05-2011, 04:48 PM   #47 (permalink)
astroboy's Avatar
As pics are worth 1000 words have any shots of it mounted (from under the car)? Also what angle did you settle on?
Old 05-05-2011, 06:09 PM   #48 (permalink)
ThePass's Avatar
Don't have a pic of that, and now it's off for Miata Challenge.. about 13 degrees though.
Old 05-05-2011, 10:36 PM   #49 (permalink)
LUV2TURN's Avatar
Now this is what a Miata should be like, excellent!
I'm going to start "shitted."
My MX6 is shitted.
1997 C-package. Shitted.
LUV2TURN is offline   Reply With Quote
Old 05-06-2011, 07:00 AM   #50 (permalink)
JSanker's Avatar
Are the foglights in the turn signal location your primary source of light?
If so, how does it compare to stock lighting and what foglights are you using?
I am contemplating a similar setup.
JSanker@ucla.edu
JSanker is offline   Reply With Quote
Old 05-06-2011, 08:39 AM   #51 (permalink)
Herpity Derpity
Mazduh's Avatar
Love your car, your doing what I wish I could do. Track events around here though are just so ridiculously expensive to get into.
Build #361 2005 Mica Black MSM:
www.FukYeaMiatas.me
I like how dick cums with its own sawce.
Mazduh is online now   Reply With Quote
Old 05-06-2011, 09:11 AM   #52 (permalink)
astroboy's Avatar
Cool, do you by chance know what angle they are mounted at on the Loti?
Old 05-06-2011, 02:46 PM   #53 (permalink)
ThePass's Avatar
Yes, those are my headlights. PIAA-P3000's. The original headlight area is gutted - the headlights covers are just held there with aluminum brackets. Saves ~10lbs per side (factoring in the weight of the new lights), and my intercooler piping takes up that space now. Light output is plenty to get me around town. Comparable to stock low beams.
I don't. Some quick research on a Lotus forum would probably answer that though. I "eye-balled" it to be about the same as a Lotus.
Old 05-06-2011, 05:05 PM   #54 (permalink)
Nice job on the car I like it.
95 Miata classic red w/ Hardtop
JJay03 is offline   Reply With Quote
Old 05-11-2011, 02:23 AM   #55 (permalink)
pevosan's Avatar
I love your car
pevosan is offline   Reply With Quote
Old 05-16-2011, 04:13 PM   #56 (permalink)
ThePass's Avatar
Lots of minor things going on here and there.
Fixed the alternator bracket that sheared a bolt at Buttonwillow.
Painted the hood red because I was tired of the white. I used basic spray paint so it turned out pretty meh but at least it's red for now. Also painted the A-pillar black. Pics of that later.
Following pics are all crappy cell phone snaps...
Put a tow strap on the rear and used a $2 Home
Depot bathroom robe hook for a hook for it so it doesn't dangle:
Still need to get TOW stickers to point out the hook.
Made a barrier out of sheet metal for the driver's footwell so that if the fire extinguisher mount fails it can't roll forward under my feet:
Although right now I'm just running at Miata Challenge events with Speed Ventures, if in the future I attend a cheap track day that doesn't offer transponders/timing, I wanted to have a way to log unofficial times:
Old 05-17-2011, 10:38 PM   #57 (permalink)
astroboy's Avatar
Sweet man. I hope the bracket doesn't fail, you'd have a very angry extinguisher jamming your feet into whatever petal your foot was on. Also is the tow sticker required?
Old 05-22-2011, 01:07 PM   #58 (permalink)
ThePass's Avatar
Tow sticker isn't required, but in the event that I go off course, I could be sitting pretty deep in the kitty litter so I want to be sure the tow guys see that there is a tow strap under there.
Old 05-22-2011, 01:24 PM   #59 (permalink)
BracedEunos's Avatar
Very Cool. I like where this is going.
www.flipsidecustoms.com
BracedEunos is offline   Reply With Quote
Old 05-22-2011, 01:26 PM   #60 (permalink)
ThePass's Avatar
So yesterday I raced at the BMWCCA autocross at Qualcomm stadium, and it was a great success for me!
First, the West Qualcomm lot is HUGE. Easily quadruple the size of most autocross areas. Second, the BMW guys like their big cars and big horsepower, so the course mixes traditional SCCA-like elements like slaloms and tight chicago boxes with big track-like sections like high-speed 3rd gear decreasing radius sweepers. Guys were hitting 80 mph around a turn! In short, not the normal miata-biased environment most autox's are
I'm usually in the top 10% at these events on my take-off goodyear slicks on 13" wheels, but with the turbo that setup actually shortens my gearing too much.
So, I gave my new track wheel/tire combo a shot - the 225 RS-3's and 9" 6UL's.
Won X-class (non-bmws) against a seriously fast STI and a very quick S2000 among about 15 others.
Set TTOD!!! This is a first for me in the last 5 years or so I've been autocrossing. I never expected it to be at a horsepower-dominant BMW event either. There are a lot of very serious drivers with lots of M3's on hoosiers, fully prepped Mini Cooper S's, a stripped and caged M3 with a LS1 in it, etc.
So happy right now
