My NA becomes a track car (Build thread) - ClubRoadster.net
Old 04-07-2011, 03:26 AM   #1 (permalink)
ThePass's Avatar
Default My NA becomes a track car (Build thread)
**Prepare to see the worst paint condition you've ever seen on a miata. Just fair warning. Yes I’ll be getting it painted soon. **
I decided there's no time like the present to start doing what I've been dreaming of: time attack in Miata Challenge. Car stays street legal, and I drive it a lot, so there's still a need to balance track needs with street needs, but the car needed a few things to be properly ready for track abuse.
First off, needed a more serious driver's seat. Found a great deal on CL for a Sparco Circuit (FIA) with normal wear and tear. Mounting involved bolting the sidemount brackets to a modified Corbeau bracket, fixed position, no slider. This seat is a pain in the a** to fit due to the dimensions at the top, especially with a soft top, but I made it happen:
This made it possible to move my old driver’s seat – a Momo Start – to the passenger side for instructors. The Sparco is crazy tight and rigid, I literally feel bolted into the car in it, which is pretty cool. I paired a quick release hub with my NRG steering wheel about a year ago, never really used the quick release much, but now I am really relieved that I have it - getting in/out over the high sides of the Sparco Circuit is nearly impossible with the steering wheel in place.
Next was the exhaust. My old setup was a 3” dump at the rear axle. It simply wouldn’t have any hope of passing sound at Laguna Seca. I had the turn down tip cut off and 3” mandrel pipe ran out to the back above the diffuser, exiting out the side of the rear bumper behind the wheel. The muffler has a removable silencer, which will be crucial for tracks with sound limits.
Old Exhaust:
New Exhaust (will get to the wheels in a minute):
Oil cooler is basically a necessity for a turbo motor on the track. Mocal thermostat plate, FM sandwich plate spacer, push-lock fittings, aeroquip hose, Trucool oil cooler. While I was in there I added the tow strap from Saferacer. Still need to add a tow strap for the rear. Just took one quick crappy phone pic before putting the nose back on:
Bumper on, tow strap hanging out:
Found a guy on this forum who offered to trade me his Torsen for my Open diff + cash, so I scored a Torsen for $300. Along with that I got to swap my line for his SS brake and clutch lines for $50. Drove up to his place in Irvine and swapped it all on the side of the road:
The big purchase was wheels and tires. Need a dedicated set for tracking (already have a street set and a autox set), and was tossing between the TR wheel or other cheap 15x8s, and then came across an amazing deal on CL for brand new, still in the box 15x9 6ULs for $600 with all eight 949 valve stems included. Could not pass it up. Paired them with Hankook RS-3's in the tried and true 225-45-15.
My rear fenders are flared and the front fenders are extremely pulled to fit my autox and street wheels. The result is whereast these 15x9's barely fit on most NAs, they actually look sunken in on my car, but that is great for aero, aesthetics aren't the priority here:
These are seriously meaty. Grip is ridonculous for a street tire. They make my Azenis feel like all seasons.
Rear view with the top up:
Rear View, top down (I'll be running top down for MC - I'm maxed on points for Mod class, so hardtop is not an option, plus I prefer this for the fun factor) :
Last, attended a dyno day to do a little check up on the motor and make sure it's still strong. I also set up an in-car switch for high-boost and low-boost. I'll be running the low boost on track for engine longevity and maximum fun.
Almost two years ago I dyno'd at 206 whp / 179 ft-lbs. Boost hasn't been changed (10psi), but better exhaust now and new plugs/wires/PCV/etc. Put down 207 whp / 208 ft-lbs. Strong.
As for the low boost for track, I'm having trouble getting the turbo to spool at any lower than 7psi. I was hoping for 4.5-5 psi and ~150 whp, I'm not sure if the exhaust is too free-flowing, or what, but with the wastegate full loose it still holds at 7 psi, which put down 185 whp / 180 ft-lbs.
That's about it. Car is pretty much ready to go for April 17th at Buttonwillow. Still need a tow strap on the rear, and I have to pull the rear diffuser off in order to fit under the 15.5 point limit for Mod class. I'd also like to try to get the low boost setting a bit lower.
-Ryan
Red '90 Turbo 1.6 - 207whp/208 ft-lbs - track car - Innovation by Blackbird Fabworx
Green 1999 - stock DD
2008 1000RR - 172 rwhp "You live more for 5 minutes going fast on a bike like that, than other people do in all of their life" -Marco Simoncelli
2003 600RR - track bike
ThePass is offline   Reply With Quote
Old 04-07-2011, 03:43 AM   #2 (permalink)
ov3r9000's Avatar
Default Re: My NA becomes a track car (Build thread)
Cool car and paint isn't to bad u should look at mine lol
1993 Miata project cheap ass track toy
2012 Subaru WRX WRB 5dr Work Meister S1 3P Nameless Performance Muffler Delete
ov3r9000 is offline   Reply With Quote
Old 04-07-2011, 04:01 AM   #3 (permalink)
Conundrum's Avatar
Paint is fine man, nothing horrible. Overall im liking it a lot. Hope you kill it at button willow.
Originally Posted by suzuki_rider_327 View Post
Clubroadster, it starts trendy word sayings.
Originally Posted by Caboose View Post
You know who really takes you seriously. Me.
Just kidding, No really
Ha, just kidding again. No, but seriously
FOOLED YOU AGAIN BRO
Conundrum is offline   Reply With Quote
Old 04-07-2011, 04:13 AM   #4 (permalink)
!n-joy
VagaXt's Avatar
Nice build. Don't worry about the find speed in the car, but rather look into you optimizing the car for your needs. Bryan Wood is a tough cookie to beat in Modified class, so I'd use him as the benchmark. Also, don't worry about losing the diffuser, you won't lose too much lift reduction from not having it.
VagaXt is online now   Reply With Quote
Old 04-07-2011, 04:27 AM   #5 (permalink)
ThePass's Avatar
Thanks. I've just focused on the things that were necessary for track use; needed another race seat so I could have an instructor ride with me (used to be only one seat), braided lines for safety, oil cooler and dedicated wheels/tires for reliability, tow strap required, etc.
I'm going into this a rookie, and focusing 100% on learning, building skills, and accumulating seat time. Now that the car is ready, it'll just be upkeep and maintenance for it.
-Ryan
Old 04-07-2011, 04:36 AM   #6 (permalink)
!n-joy
VagaXt's Avatar
"Focus more time on driving and less on car setup/fixing." You are very wise. More importantly, have fun.
Old 04-07-2011, 05:06 AM   #7 (permalink)
Whiskey makes me Frisky
Skinnyroadster's Avatar
Paint looks way better then mine did.
Love the front fenders.
Subscribed
Originally Posted by aarrowadscom View Post
That's it. That is the post that has killed me.
Forever in my heart.
http://25.media.tumblr.com/tumblr_m2...9ako1_1280.jpg
http://25.media.tumblr.com/tumblr_m7...9ako1_1280.jpg
Skinnyroadster is offline   Reply With Quote
Old 04-07-2011, 05:20 AM   #8 (permalink)
mitch_f1's Avatar
+1; those front fenders look amazing; almost stock!
I really like the diffuser you made, and the air diverter. Do you have any pictures of the diverter off the car?
mitch_f1 is offline   Reply With Quote
Old 04-07-2011, 05:29 AM   #9 (permalink)
Hide yo kids hide yo wife
batou's Avatar
This car is awesome. budget, and it works. I'd like to pick your brain sometime.
batou is offline   Reply With Quote
Old 04-07-2011, 05:32 AM   #10 (permalink)
ThePass's Avatar
Diffuser is from a Lotus Elise. The splitter I made from Alumalite. No pics with it off, but it's a pretty basic shape.
Old 04-07-2011, 06:38 AM   #11 (permalink)
LastClick's Avatar
wow this is a awesome car/build! Looks really serious
LastClick is offline   Reply With Quote
Old 04-07-2011, 08:47 AM   #12 (permalink)
Mufasa in Training
Bryan's Avatar
Don't you have to add the same belts for the passenger?
Originator of OEM Plus™
That's a really bromantic dream; miatas, fishing, Bryan... Does it get better?
Bryan is offline   Reply With Quote
Old 04-07-2011, 08:51 AM   #13 (permalink)
psyco's Avatar
^nah let them fly out the window.
psyco is offline   Reply With Quote
Old 04-07-2011, 08:56 AM   #14 (permalink)
WildCJ5's Avatar
Nice work, nice car!
WildCJ5 is offline   Reply With Quote
Old 04-07-2011, 10:49 AM   #15 (permalink)
ThePass's Avatar
Forgot to mention that on the still to do list. Currently tossing between a couple harnesses on ebay. Gotta hurry it up though, only a week and a half away.
Old 04-07-2011, 10:53 AM   #16 (permalink)
Mufasa in Training
Bryan's Avatar
Just making sure you'd thought about it
Old 04-07-2011, 10:58 AM   #17 (permalink)
fender gap is the enemy
r-unit69's Avatar
definitely diggin it. well done!
Originally Posted by Sweets View Post
Lip is a solid 3 jelly beans deep. Baller status
r-unit69 is offline   Reply With Quote
Old 04-07-2011, 11:01 AM   #18 (permalink)
Official Armchair Racer
stormin'norman's Avatar
This is way cool. Will be following along!
"I think I'll go buy one of those large foam hands you see at sporting events and zip tie it to my left mirror in a permanent point-by position." -Rich Cohn Lee
stormin'norman is offline   Reply With Quote
Old 04-19-2011, 12:27 PM   #19 (permalink)
here for farts
how did buttonwillo go? car will look sweet with hard top.looks great so far
rysmiata92 is online now   Reply With Quote
Old 04-19-2011, 12:35 PM   #20 (permalink)
King of Hella Stance Swag
monkey.magicx's Avatar
From what I remember, the HT doesn't add any points. Why wouldn't you add it?
Anyways, great looking car!
92 NA6 - Dead.
99 NB8 - Rice plate.
GarageStar
caosgomoo
Fat Cat Motorsports
monkey.magicx is offline   Reply With Quote
Old 04-19-2011, 01:07 PM   #21 (permalink)
That exhaust is badass!
My Build Thread
imput1234 is offline   Reply With Quote
Old 04-19-2011, 01:18 PM   #22 (permalink)
ThePass's Avatar
The track day was great!
Camping at the track, budget style:
This being my first official track day (I don't count Miatas @ MRLS), the first 3 sessions were really just getting the feel of things, learning the track, getting comfortable etc. Lap times dropped from 2 : 35 for the first session to 2:17 by the end of the 3rd.
The 4th session is when I started feeling like I was connecting corners together and carrying enough speed all the way through to use the whole track on exit, etc. But then an intercooler hose blew off on the first lap that felt fast, so I pitted and fixed it and got back out on track in time for just one out lap plus a flying lap. I did the flying lap at 3/4 throttle to just get a good lap in without the hose coming off again and did a 2:13.
Back when I upgraded to beefy hose clamps, I left one old clamp on because it was a biatch to get to, and naturally that's the one that failed me at the track. That will teach me.
All in all though, I had an amazing time, and the car felt great. All of the big dogs who usually run in Unlimited had their Mod class cars there and were running in my class. Andrew Savington did a 2:09.5 in the same session in a fully stripped and caged miata on 225/45 NT-01's, and his dad in the same car was doing 2:12's, so I am pretty happy - there lots more left in the car, but with my beginner-ness and not getting more than one lap in once I was comfortable with the track, I couldn't have asked for more!
Some highlights:
-Getting a point-by by a yellow S2000 coming out of the last corner onto the front straight. He moves off the line and points me by but doesn't lift and we end up drag racing side by side down the front straight. At my low-boost 185 whp, I still pulled a car length on him by the braking zone for the first corner
-In the 3rd session spending a good 3 laps just matching speed with a white turbo miata and flying around the track. We ended up finding out in the 4th session once I got some confidence that my car was a lot quicker than his, but just cruising around at a 2:17 pace with him was really fun.
As an update, I added a fire extinguisher to qualify for the -0.5 points in MC:
And I removed the rear diffuser so that I didn't take the +1 point in MC for rear aero. This and the fire extinguisher bring me down to 15 points so that I am in Mod class. I also added the rear tow hook, which I need to fab a little hook for so it doesn't hang down:
Old 04-19-2011, 01:20 PM   #23 (permalink)
ThePass's Avatar
For some reason I thought it added a point for the aero, but I was mistaken. Still, my outright goal here is not to be the fastest, it's to have fun. Running top-down is really really fun. I'm on a budget, so if a hardtop falls in my lap for an unbeatable deal, I'll go for it, but I'm not in a hurry.
-Ryan
Old 04-19-2011, 01:30 PM   #24 (permalink)
I can haz custom title!
Love you car, good work. I can't wait to hear more about you beating on it at the track.
"When life throws an unexpected curve, brake late and accelerate early."
- Me
sydwayz is offline   Reply With Quote
Old 04-19-2011, 02:15 PM   #25 (permalink)
LastClick's Avatar
Looks like so much fun driving this car around the track, and camping afterwards
Old 04-19-2011, 02:21 PM   #26 (permalink)
freedomgli's Avatar
Nice ride! Love the exhaust, aero and motor build. Looks like a lot of fun.
Old 04-19-2011, 02:30 PM   #27 (permalink)
BrownMiata's Avatar
Wow. I want your rear Diffuser.. Bad!
During my service in the United States Congress, I took the initiative in creating the Internet. - Al Gore, March 9, 1999: On CNN's Late Edition
Originally Posted by nickwild7 View Post
you done having your rant??
if you dont like the thread shut your mouth and move on.
BrownMiata is offline   Reply With Quote
Old 04-19-2011, 02:30 PM   #28 (permalink)
Got any videos to share with us?
Old 04-20-2011, 01:15 AM   #29 (permalink)
ThePass's Avatar
With all the craziness of being at my first track event, I didn't even think to use the GoPro until the final session, and I had had the intercooler pipe blow off in the previous two sessions, so I was taking it easy and just seeing if it would hold.
Video is of one warm up lap at maybe 3/4 throttle and passing a single lonely S2000, and then on the following lap I start to push a little and it blows off again and I throw my hands in the air.
The camera location is crap. My rollbar mount is faulty so this was my only option.
http://youtu.be/icYcNvU3zyM
Old 04-20-2011, 12:12 PM   #30 (permalink)
TSR85's Avatar
Nice build. Im digging the diffuser too!
Quick question, Im kinda liking that dash guage pod, which one is it, or were did you get it from?
TSR85 is offline   Reply With Quote
