mrpham's ITB build - Page 4 - ClubRoadster.net
Old 05-14-2012, 07:52 AM   #91 (permalink)
mrpham's Avatar
Default Re: mrpham's summer build
Originally Posted by felinkinkin View Post
Nice job,
regarding the "wire splits" did you know, which wire have splits , and used for?
I found a lot of wire splits on an english NA, and i don't know if it's for the car alarm (deleted) or for something else
Most of them splices/splits are for ground, power and headlight wiring.
My wiring doesn't have alarm so not sure how that would be wired up.
My Blog -
My ITB MX-5 Build -
mrpham is offline   Reply With Quote Quick reply to this message
Old 05-14-2012, 09:39 AM   #92 (permalink)
felinkinkin's Avatar
for example , this one?
Where it's located, near to the fusebox or ECU?
felinkinkin is offline   Reply With Quote Quick reply to this message
Old 05-14-2012, 07:16 PM   #93 (permalink)
mrpham's Avatar
That wire is close to the fuse box just under the dash, and from memory that wire is for the indicators.
My Blog -
My ITB MX-5 Build -
Old 05-15-2012, 04:38 AM   #94 (permalink)
thks
Old 05-17-2012, 05:32 AM   #95 (permalink)
Canaille's Avatar
Nice work MrPham!
A question on that window air vent : could someone get it off the window just by pulling it ?
Just like you I could use some more airflow in my car, but I park it on a public car park, doesn't want anyone to mess around with it.
Wondering if a big o-ring seal can be added to keep water out, and a spring split pin could be used to secure it closed.
Keep it up, your build and attention to detail is inspiring !
Canaille is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 10:03 AM   #96 (permalink)
mrpham's Avatar
Originally Posted by Canaille View Post
Nice work MrPham!
Thanks mate!
If someone really wanted to they could break the bend the vent and pull it out. It's not too easy though, but one way to make it even harder would be to install a rod on the inside so that the vent cant be removed from the outside. It's a good upgrade because it flows so much more air.
My Blog -
My ITB MX-5 Build -
Old 05-17-2012, 12:59 PM   #97 (permalink)
Looking good!
AlphaOne is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 01:13 PM   #98 (permalink)
Mr. MattMan's Avatar
Where do i buy those windows..
Fully built ITB Turbo 1.65L
Sponsors: Levels Performance /GARAGE STAR/Invision Autohouse
/Jass Performance / FAB9 TUNING / PROSPORT GUAGES / BC RACING
Mr. MattMan is offline   Reply With Quote Quick reply to this message
Old 05-17-2012, 01:19 PM   #99 (permalink)
Canaille's Avatar
I can't picture the rod you're referring to.
Would you have a link to share for the vent ?
Old 05-17-2012, 01:44 PM   #100 (permalink)
Canaille's Avatar
I don't want to hijack this thread on the window vent thing, but I've found some interesting links. I thought I'd share.
http://www.wicksaircraft.com/catalog...h=U05BUCBWRU5U
http://www.ultralightnews.ca/airvents_uslk/
http://www.falconaircraft.cz/en/inze...indow-profitex
The last one can be secured from inside.
Old 05-17-2012, 07:02 PM   #101 (permalink)
mrpham's Avatar
Hey mate, can purchase them here:
http://www.advanced-autosports.com/i...roducts_id=127
NoPro in Japan uses a rod:
I've seen those vents before, the one that can be secured, but wasn't sure how effective their flow would be.
Also regarding water sealing, mine does fine even through heavy rains or the car wash. No leaks at all.
My Blog -
My ITB MX-5 Build -
Old 05-18-2012, 04:00 AM   #102 (permalink)
Canaille's Avatar
thanks mate!
Old 05-24-2012, 02:41 AM   #103 (permalink)
mrpham's Avatar
Build Update - http://omgpham.com/build-update
Not much has been happening but some updates for the build so far.
I received my first batch of Brake Cylinder Braces, so took some photos of what it looks like installed. It's too hard to take photos of the install, so will be doing it on a bare chassis in a few weeks.
Excuse my dirty engine bay.
I've also decided to ditch the old style CAS and go with dedicated crank and cam angle sensors. They're used in later model BP4W engines as well as NB6 engines.
Started my ECU harness too. Re-used the ECU connectors and just de-pinned the terminals so I could solder new wires on. Was a tedious process but well worth it, sensors/injectors/coils connectors will be installed later.
mmmm so fresh so clean.
Cleaned up all the connectors that I plan to re-use, de-pinned and bought new rubber seals.
Picked up this cool passenger foot well plate from MX-5 Plus. No idea what brand it is, but it looks useful as it'll give me more space for the MegaSquirt and fuse/relay panel.
Made a decision to get rid of the of standard coil/ignitors and go with the very popular "Toyota COPs". Coil-On-Plugs provide a much better spark as well as giving me sequential spark with the MegaSquirt.
My Blog -
My ITB MX-5 Build -
Old 05-25-2012, 03:53 AM   #104 (permalink)
mrpham's Avatar
ITB Assembly - http://omgpham.com/itb-assembly
The enamel paint on the ITBs finally dried, didn't air dry in 7-days like the instructions said. And I actually had it in the oven for a total of 12-hours at 60degrees. That was annoying...
Anyway, I had some time today so I went for a drive in search for new throttle plate screws. The factory screws are M3 which are "mushroomed" from factory to stop them from ever backing out. I drilled these out so I could pull apart the throttle bodies for sand-blasting and paint. Checkout the photos here - http://omgpham.com/itb-strip-clean.
The shop is called Small Parts & Bearings, they stock a huge range of screws and taps. Had a chat with them at the shop and they recommended the M3.5x0.6 Hex Cap screws. I bought the required tap too, total was $18. Not too bad I thought.
First step was to drill out the hole slightly and then tap the new thread.
Just test fitting the new screws, had to cut/shorten the screw too.
The assembly station, used a syringe to apply oil in the tight spots. Also picked up some spare ITBs for parts, was great having them there so I could check how everything went back together.
One throttle body done, three more to go.
All four throttle bodies assembled!
This next part is a bit hard to explain, but basically the Toyota throttle linkages don't really match up with the stock Mazda throttle cable. There's a bit of slack as well as not enough travel in the throttle pulley. The idea is to make more space between the throttle cable stop and the throttle linkages, this removes any slack in the cable. It's quite straight forward to do, just have to move some parts around so that the throttle linkages sit on cylinder #3 and #4 instead of #2 and #3.
After re-assembling the throttle bodies, the service manual outlines the procedures to adjust all four linkages that "daisy-chain" the throttle bodies together. I'll do that in the next couple of days hopefully.
I can't wait to get these on the car!
My Blog -
My ITB MX-5 Build -
Old 05-25-2012, 06:36 PM   #105 (permalink)
mrpham's Avatar
My Blog -
My ITB MX-5 Build -
Old 05-27-2012, 08:31 AM   #106 (permalink)
Canaille's Avatar
Nice work !
One comment on the screws you used though : the head is quite large and will generate some aerodynamic troubles.
I own a Mini. Carburetor tuning include shaving the head off (not entirely) and reduce the shaft thickness. Can you get some different screws ?
Old 05-28-2012, 03:51 AM   #107 (permalink)
Those AE itbs are coming along nicely! What fuel rail are you going to use? Injectors? throttle linkage?
Old 05-28-2012, 08:21 AM   #108 (permalink)
mrpham's Avatar
Nice work !
Thanks mate. Took your advice and got new screws in, will show you photos soon.
M-Tuned rail, 1.8L injectors and not too sure about throttle linkage setup yet. Will update as soon as I figure it out.
My Blog -
My ITB MX-5 Build -
Old 05-28-2012, 09:14 AM   #109 (permalink)
mrpham's Avatar
ITB Update - http://omgpham.com/itb-update
In my previous update I posted up about reassembling my ITBs. I had to use new screws to hold the throttle plates as the old ones were drilled out, they were replaced with socket cap screws but I was recommended to use something with a smaller profile head. I've now replaced the screws with button head socket screws.
The screws were also cut down so not much thread was left sticking out on the other side.
Spent some time over the weekend dialing up the ITB adjustment screws, still a few things to sort out and hopefully they won't cause issues down the track.
Stupid little adjusting screws, very tedious!
Finally received my FPR adapter piece for the M-Tunes fuel rail.
Gave the foot-well plate a good clean.
My Blog -
My ITB MX-5 Build -
Old 05-28-2012, 01:38 PM   #110 (permalink)
Canaille's Avatar
Glad I could help! Your set up is extremely clean, pro level!
(have you put loctite on the screws ? You don't want one to kiss a valve )
Old 05-28-2012, 09:46 PM   #111 (permalink)
Yeah definitely put some loctite on those screws for throttle plates
Old 05-28-2012, 09:51 PM   #112 (permalink)
mrpham's Avatar
For sure, used loctite on all throttle plate screws. Backed them in and out a few times while the loctite was wet just to make sure all the threads received a good coat.
My Blog -
My ITB MX-5 Build -
Old 05-29-2012, 06:54 PM   #113 (permalink)
Kool. Looking forward to more updates man
Old 06-05-2012, 03:26 AM   #114 (permalink)
mrpham's Avatar
Wiring Update - http://omgpham.com/wiring-update
Small update... some wiring parts arrived and picked up a white board to help me scribble down wiring stuff. It's been pretty handy
According to the MegaSquirt manual, it's a pretty good idea to shield the TPS and trigger wires. So have been on the search for a flexible 2-core shielded cable, ended up deciding on a microphone cable from JayCar (part no. WB1530).
Terminated the shielding into it's own BLACK wire, this will grounded at the ECU end and left floating on the sensor end. The BLUE wire will be used for sensor return and the WHITE for sensor ground. The +5V/+12V wire will be run externally to the shield.
My awesome PURPLE (and grey) Deutsch connectors, all solid terminals too.
This is the relay block I'll be using, it's all modular so you can expand if needed.
My Blog -
My ITB MX-5 Build -
Old 06-06-2012, 01:57 AM   #115 (permalink)
Good work man
Old 06-18-2012, 03:33 AM   #116 (permalink)
mrpham's Avatar
Engine Harness & Wiring Parts - http://omgpham.com/engine-harness-wiring-parts
So a few weeks back I started working on the ECU/engine harness, this was re-using old connectors and terminals. Was never happy about re-using those parts...
How it was with the re-used parts.
Fortunately I was able to find the part numbers for new parts, all sourced locally from RS Components too! All parts are manufactured by Tyco/AMP and the part numbers are below:
I also found a very good source for automotive wiring in Brisbane, the company is CECA and located in Geebung. They stock Tycab's full range of automotive cabling.
All new connectors and terminals!
Also started on my Deutsch connectors, love these things!
All terminated... this connector is used for all coil and injector +12V wires.
As a precaution, I also did continuity checks for every wire and terminal used.
These are the parts I picked up to do my dedicated fuse/relay panel. Includes terminal bar, bus bar, fuse block and a relay block.
On the left are the brand new terminals I used, and the right is the FD RX-7 battery fuse block. This is where I'll be relocating all my main fusible links, sits on the positive side battery clamp.
My Blog -
My ITB MX-5 Build -
Old 06-18-2012, 03:42 AM   #117 (permalink)
95montego's Avatar
most of the time, people hate the wiring portion of a build, and it looks like you just dove in head first. Kudos to you sir, ku-fucking-dos!
95montego is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 02:20 PM   #118 (permalink)
Awesome work
Old 06-18-2012, 02:26 PM   #119 (permalink)
etikoner's Avatar
I'd pay good money for someone to do wiring like that on my car.
Call me Erick.
- The story of my 95M
Motion Motorsports| SGS Racing| Garage Star| Miata Society
etikoner is offline   Reply With Quote Quick reply to this message
Old 06-18-2012, 05:41 PM   #120 (permalink)
mrpham's Avatar
Awesome work
Thanks! just can't wait till everything is installed so I can drive it
My Blog -
My ITB MX-5 Build -
Tags
dipstrap
