Help me RX7 noob thread - Page 3 - ClubRoadster.net
Go Back   ClubRoadster.net > PROJECTS & BUILDS > Non-Roadster Projects
Non-Roadster Projects Got an ongoing project on your non-Roadster? Post about it here.
Old 09-28-2016, 10:08 AM   #61 (permalink)
pitbulls on my pantleg
deprogram's Avatar
Default Re: Help me RX7 noob thread
Subbed for more rotary porn.
This is making me want an FB all over again. Maybe this winter.
my
i wrote a
for android
deprogram is online now   Reply With Quote Quick reply to this message
Old 09-30-2016, 11:46 AM   #62 (permalink)
Red Sun's Avatar
Admire your work so far, that's quite a mess to sort out. I'm extremely jealous of the deal you got. Those rotaries look like so much fun to work on. The rebuild videos ive watched are fascinating. I'm hoping to buy a roller in a few years, but for a V8 swap..
Red Sun is offline   Reply With Quote Quick reply to this message
Old 10-02-2016, 07:12 AM   #63 (permalink)
whinin's Avatar
So now I need to find a new rear plate. All the other plates/housings are usable though, this was the only bad one. Luckily this was the last one I was cleaning, otherwise finding this I would have stopped right there lol.
'96|DD Canyon Carver
'92|Built Turbo Turd @ 16psi
'93 RX7|Under Construction
whinin is offline   Reply With Quote Quick reply to this message
Old 11-13-2016, 04:14 PM   #64 (permalink)
whinin's Avatar
Been a bit. Just an update. Got a decent condition rear plate and a good condition center plate. Started cleaning the rotors more thoroughly and putting them together. I knew at some point I was going to have to buy more parts because I would mess something up. Luckily it was just the side seals. OEM mazda side seals come a little longer so you can customize the fit, and I ground too much off 2 of them and the clearances are too high.
Old 11-18-2016, 07:54 PM   #65 (permalink)
whinin's Avatar
Got the clearances set on 1 side of each rotor. I can't believe I didn't have any vaseline to hold stuff together.
Old 11-18-2016, 10:16 PM   #66 (permalink)
100percentjake's Avatar
Just read through the whole thread. I know nothing about rotaries but this is some good stuff.
I make bad decisions.
100percentjake is offline   Reply With Quote Quick reply to this message
Old 11-21-2016, 08:45 PM   #67 (permalink)
caliboy15's Avatar
what's the papers on this? Im sure it was not imported under 25yr law rule
Lol. Dont be a hater because i got better shiz than you.
caliboy15 is offline   Reply With Quote Quick reply to this message
Old 11-24-2016, 06:13 PM   #68 (permalink)
whinin's Avatar
No clue but I have title for it in my name.
Old 11-29-2016, 11:13 AM   #69 (permalink)
caliboy15's Avatar
Id find out if I were you... you don't want feds knocking on your door and taking your car
Old 11-30-2016, 12:04 PM   #70 (permalink)
whinin's Avatar
Nope I know that risk.
Old 12-16-2016, 08:44 PM   #71 (permalink)
whinin's Avatar
Besides in a few months it will be A OK.
Sourced a better rear plate than the one I bought earlier. Don't like the staining.
Should be put together in the next month.
Then hopefully I figured out all the hiccups in the ECU....
Old 02-26-2017, 06:13 PM   #72 (permalink)
whinin's Avatar
Got the keg put together today. Man what a pain in the ass. Apex seal springs are tiny and fidgety. Ughh.
Old 03-01-2017, 03:40 PM   #73 (permalink)
whinin's Avatar
Taped and in the process of painting it. Going with metallic black/gold/black.
Old 03-04-2017, 04:42 PM   #74 (permalink)
whinin's Avatar
So. Must. Rust....
Think I did ok cleaning it up, and I think the flywheel/clutch look good to be re-used. There is much meat left on the clutch disc too.
Old 03-07-2017, 08:17 AM   #75 (permalink)
$1500 for that? Since it seems like you know how to work on cars and have access to all the tools this should be a pretty awesome setup. Can't wait to see the final result.
Is it difficult to put together a rotary engine compared to say an i4?
foobar321 is offline   Reply With Quote Quick reply to this message
Old 03-08-2017, 08:56 AM   #76 (permalink)
namelesspenguin's Avatar
I find it easier. There's a lot less moving parts to a rotary as opposed to and I4, especially if it's na. But of course, you just gotta have patience and be meticulous. It's easy to do something wrong. With all motors.
seriously guys, its just a miata, its not baller status LOL
completely unnecessarily necessary.
it's like an optional mandatory part.
namelesspenguin is offline   Reply With Quote Quick reply to this message
Old 03-10-2017, 07:49 PM   #77 (permalink)
whinin's Avatar
Yeah once I got 2 of the apex seals/springs in the pressure caused the last one to be a giant pain in the ass to get right. Assembling the front stuffs and checking end play tomorrow, then full on assembly of the front cover and starting to put accessories on it hopefully. I need to change the oil in the turbo turd miata and check some exhaust bolts but hopefully after that I can work on the 7.
Old 04-10-2017, 02:11 PM   #78 (permalink)
whinin's Avatar
Little more work done. Measuring end play. .04mm fully assembled.
Old 04-19-2017, 01:26 PM   #79 (permalink)
whinin's Avatar
Also got the oil pan on (have to re-thread a m6x1.0 hole) and the motor mounts (have to find another mount bolt)
Turned it over by hand with a few squirts of oil in each housing and I have solid compression on each face of the rotor. Pops a little oil spray out with each pass by the exhaust ports. Yay!
Old 04-26-2017, 02:21 PM   #80 (permalink)
whinin's Avatar
So scratched the oil pan gasket in favor of a Banzai Racing oil pan brace. They suggest using black rtv so that's what I did.
Also did some heat wrapping on the lower intake manifold to maybe help improve efficiency.
Old 04-26-2017, 05:40 PM   #81 (permalink)
mrryanbaker's Avatar
Good work, but man is it terrifying to see that much work being put into a car that could just be seized. You've got like ~4 years before that beast is legal if it's really a 96. Doesn't matter if it has a state title or not. Years ago my roommate had the feds show up and seize a car he had a state title for. Be careful.
1995 Black base -> 2015 Exocet
2016 Arctic White Club
mrryanbaker is offline   Reply With Quote Quick reply to this message
Old 04-26-2017, 07:18 PM   #82 (permalink)
whinin's Avatar
Based on the VIN (Autotrader Japan decoder) it is 10 July 1992, so a little over 2 months and it's legal. Title says it's a '96, but I will have to get that changed soon.
Old 05-19-2017, 03:19 PM   #83 (permalink)
Subbed. I'd love a RHD RX7 to go along with my 94..someday.
nitewing117 is online now   Reply With Quote Quick reply to this message
