Help me RX7 noob thread - ClubRoadster.net
Go Back   ClubRoadster.net > PROJECTS & BUILDS > Non-Roadster Projects
Non-Roadster Projects Got an ongoing project on your non-Roadster? Post about it here.
Old 09-02-2015, 04:29 PM   #1 (permalink)
whinin's Avatar
Default Help me RX7 noob thread
Yup. Found me a 96 RX7, right hand drive.
Car wouldn't do anything, so I checked around. Main fuse was blown. Replaced, now car will turn over but won't catch. Needs a little bit of cosmetic work. Door handles, and drivers side headlight lid. Also needs work on the brakes, they are muuuuuuushy.
You will never guess how much I paid for this either....
'96|DD Canyon Carver
'92|Built Turbo Turd @ 16psi
'93 RX7|Under Construction
whinin is offline   Reply With Quote Quick reply to this message
Old 09-02-2015, 04:44 PM   #2 (permalink)
Sponsors
Default Re: Help me RX7 noob thread
Well, I'm jealous.
PulstarSparkPlugs is offline   Reply With Quote Quick reply to this message
Old 09-02-2015, 05:39 PM   #3 (permalink)
Oooo a car that will burn a hole in your pocket. Nice pickup and welcome to the dorito life!
MiataMak is offline   Reply With Quote Quick reply to this message
Old 09-02-2015, 06:50 PM   #4 (permalink)
whinin's Avatar
Old 09-02-2015, 08:31 PM   #5 (permalink)
jdmeg2's Avatar
very nice! i just got my 93 with 27k on it not to long ago. where in SC are you?
Form<Function
ALL OF YOUR PIMP CUPZ BELONG TO ME!!!!
jdmeg2 is offline   Reply With Quote Quick reply to this message
Old 09-03-2015, 08:06 PM   #6 (permalink)
whinin's Avatar
Over in Elgin.
Also, found out why the car wouldn't start 'I think'.
Old 09-04-2015, 06:57 PM   #7 (permalink)
whinin's Avatar
Holy fuckasstits
Old 09-05-2015, 08:45 PM   #8 (permalink)
MatosMiata's Avatar
Originally Posted by whinin View Post
Yeah, that'll do it lol. Looking forward to see how this build goes.
MatosMiata is offline   Reply With Quote Quick reply to this message
Old 09-20-2015, 12:47 PM   #9 (permalink)
whinin's Avatar
Fuel system sorted out. Now onto the no spark....
Old 09-20-2015, 06:32 PM   #10 (permalink)
GreaseMonkey2000's Avatar
Since no one else asked, how much did you pay?
'01 NB2 MisF1re:
'97 M aka Warbird, gone but not forgotten:
GreaseMonkey2000 is offline   Reply With Quote Quick reply to this message
Old 09-20-2015, 09:58 PM   #11 (permalink)
Ethaniscool's Avatar
I wanna know too so I can be even more jealous.
Great find though!
1991 NA 13B TurboII Build
1975 Mazda Rotary Pickup Bridgeport 13b
93 Le #1472
"valving" does not necessarily mean better. Just like "cooking" doesn't necessarily mean tasty.
Ethaniscool is offline   Reply With Quote Quick reply to this message
Old 09-21-2015, 06:40 AM   #12 (permalink)
Rehabilitation Officer
Beef Supreme's Avatar
Being friends with a guy that owns a rotary specialist shop, and seeing how many engines he rebuilds every week.............I am not jealous of this at all. Okay, maybe just slightly jealous.........if you put an LS7 in it.
Beef Supreme is offline   Reply With Quote Quick reply to this message
Old 09-21-2015, 09:38 AM   #13 (permalink)
namelesspenguin's Avatar
I'm jealous of most rx7's, running or not. Get it running. Let me drive it.
seriously guys, its just a miata, its not baller status LOL
completely unnecessarily necessary.
it's like an optional mandatory part.
namelesspenguin is offline   Reply With Quote Quick reply to this message
Old 09-21-2015, 03:27 PM   #14 (permalink)
SilverNB818's Avatar
You should dump the oil to see if there's any coolant in it. If there is then your coolant seals are busted and probably your motor is seized up too. Judging from the fuel pump assembly, the car looks like its been sitting for awhile. Your bank account is in for a good one GL!!!!!!!
SilverNB818 is offline   Reply With Quote Quick reply to this message
Old 09-21-2015, 08:42 PM   #15 (permalink)
whinin's Avatar
Motor spins over, pulleys and all when I try to start it. I will check the oil, that's a good idea.
I paid 1500 for it
Old 09-21-2015, 09:01 PM   #16 (permalink)
I despise your existence.
'01 NB2 MisF1re:
Old 09-22-2015, 06:14 AM   #17 (permalink)
Pretty decent deal. I know people paying more than that for half assed interior rolling shells. You could have an engine fully built for big power and still spend less than paying for a good condition stock FD.
Old 09-22-2015, 08:18 AM   #18 (permalink)
I agree
blackdbl9NB is offline   Reply With Quote Quick reply to this message
Old 09-22-2015, 06:31 PM   #19 (permalink)
whinin's Avatar
So far I have a list of things to check tomorrow.
Crank sensor. Connection, condition, and resistance. Same with the cas.
ECU pin outs if the above is in good working order.
Igniter
Wires
Tomorrow I should have spark unless I have to get new sensors.
Old 09-22-2015, 07:29 PM   #20 (permalink)
rare for the cas to go bad id say.
I've had multiple igniters go bad though. the igniter is also grounded through where its bolted in so sometimes thats corroded too.
1994 RX-7
2004 Mazdaspeed Miata
silverfd3s is offline   Reply With Quote Quick reply to this message
Old 09-23-2015, 05:44 PM   #21 (permalink)
whinin's Avatar
CAS and crank sensor checked out OK, 1.14k and 1.15k resistance. Spec is .95 - 1.25k.
All listed wires have continuity at the ECU pins:
NE signal
G signal
Crank/CAS power
MAP sensor
Igniter
Circuit opening relay.
So now I'm on to checking the coils for power, but will have to wait till Sunday. I may have to buy an igniter. Is there an ECU relay?
Old 09-23-2015, 06:12 PM   #22 (permalink)
can check the yellow egi relay in the main fuse box
1994 RX-7
Old 09-29-2015, 11:37 PM   #23 (permalink)
whinin's Avatar
Yeah so I thought I did in the beginning. Well, thinking about it, I took the one out of the Miata and put in the opening circuit relay, and I don't think I tried the EGI relay.....
Will find out tomorrow if she fires up. Fingers crossed.
Old 10-07-2015, 11:56 AM   #24 (permalink)
whinin's Avatar
No go. I'm lost now.
I've tried everything.
New fuel pump/strainer/filter. Gas been sitting for a long time. Clean tank. Getting fuel coming out the feed line by the dipstick. Good pressure.
Crank sensor resistance measured on 2000 ohm setting
1) @ 1135 ohms (1.135k)
2) @ 1145 ohms (1.145k)
So, those are good. Cleaned off the surfaces with scotch brite pad for good measure
Checked continuity between ECU and:
NE signal - .007 ohm
G signal - .006 ohm
Ground (I'm guessing it's ground, each measure at the same pin on ECU) .007 ohm
Map sensor - .007 ohm
Igniter - .007 ohm
Circuit opening relay - .007 ohm
Coils show good. All within specs.
Wires show good. If I remember right, 3 were close to 2.42 and one was close to 3, setting on 20k. 16.3k per meter rated resistance.
Fuel injectors good. All within spec.
Ignition on, I'm not getting any voltage at the coils. Replaced Igniter, still nothing.
So I checked continuity on each wire coming out/in to igniter to the each coil. .007 ohm except one was at 1.0 ohm on a trailing coil.
From what I'm seeing here, this damn thing should crank up and run. However, there is one BIG thing I'm missing. Even though I could show continuity to the pins on the ECU, the ECU could still be bad. What are your thoughts?
Thanks for any help guys....
Old 10-07-2015, 02:04 PM   #25 (permalink)
'Bout dat life
reversecaoboy's Avatar
Would help to tear apart the ECU and see if any of the caps are blown or anything came loose.
I saw this happen with a 1JZ S13 at final bout. Some of the soldering broke inside the ECU.
99 NB
reversecaoboy is offline   Reply With Quote Quick reply to this message
Old 10-07-2015, 05:37 PM   #26 (permalink)
whinin's Avatar
Didn't notice anything out of the ordinary, just took it apart.
Someone on the RX7 FB group took the time out to help me for a few hours today.
ECU is getting power. EGI fuse is getting power. EGI relay is getting power. Coils are getting power (checked wrong way first time). ECU is seeing crank sensor voltages while cranking. Igniter has power.
So, ECU replacement time.
Old 10-12-2015, 08:01 PM   #27 (permalink)
whinin's Avatar
Took care of the FPD yesterday. Getting the solenoid I broke, then I have a two day weekend and hopefully enough will power to get the vacuum hoses replaced. Then to just find the coolant leak (center back of engine, comes out like a water hose on low), and hopefully the ECU fires it up! Brap Brap Brap
Old 11-02-2015, 06:30 PM   #28 (permalink)
whinin's Avatar
Waiting on fuel injectors to come back from being cleaned and flow tested...
Old 11-05-2015, 02:43 PM   #29 (permalink)
whinin's Avatar
Injectors shipped out today, have to wait on o rings to come from atkinsrotary. Service place couldn't get a hold of them.
Old 11-10-2015, 11:08 PM   #30 (permalink)
whinin's Avatar
Well uh, that might be half the problem.....
http://imgur.com/C1u8ShR
