My 2000 Ducati M900ie - ClubRoadster.net
Go Back   ClubRoadster.net > PROJECTS & BUILDS > Non-Roadster Projects
Non-Roadster Projects Got an ongoing project on your non-Roadster? Post about it here.
Old 01-28-2010, 07:53 PM   #1 (permalink)
arcana's Avatar
Default My 2000 Ducati M900ie
Bought this thing for $800 - it was repo'd and sat for a year (outside) before I found it.
So far i've done quite a bit to this bike. Working at a bike shop doesn't hurt either.
First, here's a list of things I've done:
-Extensive Cleaning
-Adjusted Valves
-Replaced Timing Belts
-Cleaned and Sealed Fuel Tank
-New Fuel Lines and Fuel Filter
-New Fuel Filler O-Ring
-Replaced Fuel Filler from S4R Monster
-Re-Wired Electronic Controls
-NGK Plugs
-Custom Plug Wires
-Full Synthetic Oil
-Custom Airbox
-K&N Air Filter
-Ducati Superbike Clutch and Brake Master Cylinders
-Brembo Clutch and Brake Levers
-Stainless Steel Braided Clutch Line
-Stainless Steel Braided Rear Brake Line
-Rear Brembo Caliper from S4R Monster (stock front Brembo calipers)
-Aluminum Rearsets
-Custom Speedometer Setup
-Diablo Corsa III Front and Rear Tires
-Clip On's
-Powercommander USBIII
-Personally Tuned Custom Fuel Map (I'll scan the dyno run)
-New Ignition Coils
-D.I.D. Premium High Tensile Strength Chain
-Personally Fabricated Custom Exhaust (from stock exhaust cans) and Custom Aluminum Exhaust Mounts
-New Clutch Springs, Caps, Pressure Plate and Basket
-Aluminum Clutch Half Cover
-Rear Frame Chop
-Custom License Plate and Tail Light Mounts
-LED License Plate Bolt-Lights
-Removed Front and Rear Fenders
I'm thinking about powdercoating the frame/wheels...the color scheme is a secret though.
BEFORE:
The previous owner tried to put a 916/996 rear tail section on the bike. They welded brackets to the frame and everything. What a waste.
What was under the tank.
During the build:
AFTER:
These pics are pretty grainy.
1997 NA8 1982 RX-7 2000 Ducati M900ie
arcana is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 08:03 PM   #2 (permalink)
Speed Racer
XCLR8TN's Avatar
Default Re: My 2000 Ducati M900ie
I was hoping for a thread when I saw your sig, lol. I gotta come back and read it tho--headed out the door!
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap ...SOON
XCLR8TN is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 08:09 PM   #3 (permalink)
jux
Mostly Harmless
jux's Avatar
mmmmmm...desmodromic
The only bike I ever wanted was a Monster, so that there makes me shed man tears it's so nice.
'90 "LE" with red bits - 7/6 Flex, FM Front Bar, 14x7 +19 RPF1, PWR, SPAL, Maxim Works, Thermal R&D, HDHCSDM2, Zoom, Anvil II, 330mm Mahogany Deep Corn, AC/PS delete, LE interior, attitude
'08.5 MS3 - AST 4100, TriPoint Rear Sway and Links, JBR STS w/ bushings & lockout plate, AP v2
jux is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 09:07 PM   #4 (permalink)
BracedEunos's Avatar
Guessing a mod will move this to General automotive chat (if that even applies).
BracedEunos is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 09:09 PM   #5 (permalink)
Fran82's Avatar
One of the few times when BIGGER pics would be nice
I must be getting old.
Fran82 is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 09:11 PM   #6 (permalink)
arcana's Avatar
Totally dude
They're just thumbnails - if you click on them they should enlarge.
Old 01-28-2010, 09:34 PM   #7 (permalink)
Fran82's Avatar
Pop-up blocker. Oops. It was just opening another screen with the same size pics. Now it's linking. Thanks.
Old 01-28-2010, 09:34 PM   #8 (permalink)
Speed Racer
XCLR8TN's Avatar
Nice find! I can't see how anyone would think that tail section looked good, lol.
New colors? Black and purple? lol I'd rock it
_Jess_
LS6 swap ...SOON
Old 01-28-2010, 09:39 PM   #9 (permalink)
Brah.
PYTHON's Avatar
pscolaNA has a bike quite similar to this. might be a good source for inspiration for your project
PYTHON is offline   Reply With Quote Quick reply to this message
Old 01-28-2010, 10:06 PM   #10 (permalink)
arcana's Avatar
Does he have a project log for it?
Old 01-29-2010, 06:09 AM   #11 (permalink)
adore's Avatar
Me to..When i first saw the movie The Crow..he had one.
adore is offline   Reply With Quote Quick reply to this message
