MSPNP part-throttle surge - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Engine Management (EFI)
Engine Management (EFI) Stand-alone solutions for your Roadster! Questions, answers, and tech-talk!
Old 08-15-2010, 11:07 PM   #1 (permalink)
Ninja Messiah
kung fu jesus's Avatar
Default MSPNP part-throttle surge
'92, MSPNP, switch to an auto TB with potentiometer TPS, no AFM.
I get part throttle surging. I switched from MAP-based accel to TPS and i still had it. The car would also stall at tip in.
so, i switched back to MAP.
ordered an LC-1 tonight to get serious about tuning this thing. it's been a while since i've tuned ECUs (mk 1 Link).
anyone have some suggestions?
i wired the auto TB as Matt suggested:
Light green / red: 5 volt VREF
Red / blue: TPS signal
Black / light green: Ground
Red: Switch, don't use this with the MS.
the wires matched to the existing manual TPS harness.
(on the side, after being a Link user for quite a while over the years, i REALLY like the MSPNP. i use a netbook for onboard diagnostic, which tethered with my phone, gives me a lot of options practically anywhere. nicely done guys!)
I ♣ baby seals.
kung fu jesus is offline   Reply With Quote
Old 08-16-2010, 11:33 AM   #2 (permalink)
Sponsor
Matt Cramer's Avatar
Default Re: MSPNP part-throttle surge
See if you can post a data log of the problem, preferably after getting the LC-1 installed. That will shed more light on the problem.
Matt Cramer
http://DIYAutoTune.com
Matt Cramer is offline   Reply With Quote
Old 08-16-2010, 11:07 PM   #3 (permalink)
Ninja Messiah
will do.
I ♣ baby seals.
Old 08-31-2010, 09:35 PM   #4 (permalink)
Ninja Messiah
update...installed the LC1 and uploaded tunerstudio onto the computer i use to interface with the MS. my TPS calibration is goofy. 200+ at closed, 249 open (the open is fine).
i re calibrated the TPS (this is an auto miata TB assembly on a manual) by hand with feeler gauges and a multimeter. i rechecked the MS TPS calibration, same readings, but the % DECREASES a lot after tip in then goes up to 100%.
Ordered a new TPS. should be here thursday.
I ♣ baby seals.
Old 09-02-2010, 09:40 PM   #5 (permalink)
Ninja Messiah
new TPS in. min value is 206, max is 251. i calibrated on tuner studio. the throttle response is better, much smoother. i feel a LOT less part-throttle hunting.
I ♣ baby seals.
Old 10-26-2010, 03:27 PM   #6 (permalink)
garageSTAR Supporter
jdmfc3s90's Avatar
Was using an AT tps sensor the only option for your set up? Could you use a manual? I did a few searches here in this forum reguarding tps and MS PnP. Im interested in comparing tps tuning and map tuning for the MS
Visit- garageSTAR
jdmfc3s90 is offline   Reply With Quote
Old 10-26-2010, 07:22 PM   #7 (permalink)
Moderator
Greg G's Avatar
Sorry--the automatic TPS plugs right into the original harness? Could you elaborate more?
Goodbye, ARC. Thanks for the awesomeness.
Greg G is offline   Reply With Quote
Old 10-26-2010, 07:47 PM   #8 (permalink)
SuperMOD
Haigog's Avatar
You can use a manual TPS but it's not as baller as the auto TPS...the manual one just reads open or closed, whereas the auto one can tell like, percentages of how open it is(there are more scientific names for these two, but I can't quite think of them at the moment)...so you can get a better, smoother tune one an auto TPS.
I believe there is some basic wiring involved in using the auto TPS.
Haigog is offline   Reply With Quote
Old 10-26-2010, 08:54 PM   #9 (permalink)
I believe he is saying the wiring color is the same. The auto 1.6 is 4 pin and the manual 1.6 3 pin.
Who you'd do and who you consider hot are separate categories that may or may not overlap.
wildfire0310 is offline   Reply With Quote
Old 10-26-2010, 09:35 PM   #10 (permalink)
Ninja Messiah
you only use 3 pins on the auto anyways. being in cali, i always set up my stuff so i can change it back easily to pass visual and or smog. all i did was buy one female connector and 2 males at radio shack. swapping the ECUs out (OEM and MSPNP), the throttle bodies (one is a manual for the OEM ECU, the other is an auto for the MS) only takes me about 20 minutes from start to finish.
I ♣ baby seals.
