Getting ready to use an AbeFM PNP MS2 Setup Questions - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Engine Management (EFI)
Engine Management (EFI) Stand-alone solutions for your Roadster! Questions, answers, and tech-talk!
Old 10-24-2010, 03:03 AM   #1 (permalink)
Denny Crane
Cross's Avatar
Default Getting ready to use an AbeFM PNP MS2 Setup Questions
So I bought a unit that was one of AbeFM's units and it seems he is not on very much (I PM'd him about a week or week and a half ago) so I wanted to touch base with those here.
Since it seems to be a Normal DIY MS2 box and then AbeFM's PNP unit added on I assume it can handle the latest MS2 Extra Code, however I find some stick to different versions for functionality.
--So whats the pref'd code all you MS2 users are using right now?
I am using Tuner Studio (The Paid Version, some of the features, wow ) but before I begin I want to make sure everything si 110% ready to go.
I also have no idea where to plug in the wideband with AbeFM's unit, it has spots I assume are to control outputs and take in signal like the Wideband's but..... whats what?
I found a few of AbeFM's threads and maybe I overlooked it but I did not see a listing of whats what there.
I also went to get the wideband, and basic gauges wired in and found when I changed the Test pipe to include a resonator I removed the Wideband O2 bung I put in... gotta fix that.
So I wanted to take the extra time to dot the "i's" and such.
(I am also going to use it to finish my Oil Pressure Gauge Mod and work on the water temp gauge mod)
Any and all input is welcome.
At this time its just a 2000 Miata with Minor Bolt ons. I have 820cc and 550cc injectors sitting here. I will run them and switch to E85 after I have played with MS a few days and drained the gas in my gas tank.
Thanks!
Denny Crane /Rotary = Fail\ -- /Bite my Shiny Metal Ass!
01 Z51 Corvette w/Bolt On's, H/C, E85 \ 05 Mustang GT HR/I/E / 96 Probe GT Turbocharged \ 06 Ford F-150 5.4L
Cross is offline   Reply With Quote
