Some intell on AEM. - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Engine Management (EFI)
Engine Management (EFI) Stand-alone solutions for your Roadster! Questions, answers, and tech-talk!
Old 10-12-2011, 01:58 PM   #1 (permalink)
Default Some intell on AEM.
Hey guys i'm kinda stuck in this, need some help. So i'm building my second Miata, its a 2001 se, i'm thinking on buying the new AEM EMS 4 but i am being told its not going to work due to the vvti head. And that i would need to either change out the head or change the intake cam. Does anyone have any information on this, and also has anyone ever changed the intake cam size on that head to one that isn't vvti.
mx03tb is offline   Reply With Quote
Old 10-12-2011, 02:01 PM   #2 (permalink)
RedemPhex's Avatar
Default Re: Some intell on AEM.
umm why? You can disconnect the VVT stuff and the head will work, but at a decent power loss. You will need to get the VVT tuner to make sure of the VVT capabilities (which can give you a decent bit of power too). I think you might have some good luck with AEM questions at mt.net
RedemPhex is offline   Reply With Quote
Old 10-12-2011, 02:05 PM   #3 (permalink)
So i can just disconnect the vvti and problem solved? What about the extra amount of oil it will be feeding that cam? Wouldn't it hurt the head?
Old 10-12-2011, 02:09 PM   #4 (permalink)
brontosaurus
1vicissitude's Avatar
I wouldn't disconnect it. You are leaving a lot of power on the table, or spool time if you FI.
I really think your questions would be best answered on AEM's forum. They offer pretty prompt tech support.
http://forum.aempower.com/forum/inde...oard,65.0.html
Originally Posted by sdemo45 View Post
Ain't no MTn fast enough;
Ain't no RD low enough;
Ain't no Mnet stock enough;
To keep CR from swaggin wif you, babe.
1vicissitude is offline   Reply With Quote
Old 10-12-2011, 02:13 PM   #5 (permalink)
RedemPhex's Avatar
its not like its spitting the oil out. If I were you, I would consider getting the VVT to work. its a worthwhile upgrade and all the turbo guys love it for better spool. If you were NA, I would say getting a second head isn't a bad idea when you get the chance or a good deal, but this is just too good to pass up if you know what I mean.
Old 10-12-2011, 02:15 PM   #6 (permalink)
the thing is i do not want to get rid of vvti, im also looking into just having some one make me a diypnp with the vvti tuner.
Old 10-12-2011, 02:38 PM   #7 (permalink)
RedemPhex's Avatar
Braineack.
Old 10-12-2011, 02:45 PM   #8 (permalink)
ill give me a ring. see whats up. I just do not want to run the fic again because it gives me limited fuel range and i want to be able to go past 10psi.
Old 10-12-2011, 02:49 PM   #9 (permalink)
jux
Mostly Harmless
jux's Avatar
Might want to chat with Savington/Track Speed Engineering about getting the VVT system to work with AEM.
'90 "LE" with red bits - 7/6 Flex, FM Front Bar, 14x7 +19 RPF1, PWR, SPAL, Maxim Works, Thermal R&D, HDHCSDM2, Zoom, Anvil II, 330mm Walnut Deep Corn, AC/PS delete, LE interior, attitude
VVT swap coming soon
jux is offline   Reply With Quote
Old 10-12-2011, 03:03 PM   #10 (permalink)
who are they?
Old 10-12-2011, 03:31 PM   #11 (permalink)
RedemPhex's Avatar
who are they?
they are not on CR. but you can contact trackspeed engineering (pretty much savington). He runs a turbo VVT car with AEM.
Old 10-12-2011, 03:51 PM   #12 (permalink)
oh ok ill check that out thank you
