| Engine Management (EFI) Stand-alone solutions for your Roadster! Questions, answers, and tech-talk! |
#1 (permalink) |
Hi guys,
Need ur help my car doesn't start... Looks like a déjà vu ? So, here's the deal ... My NA8C isn't starting for a month ! Started fine one day, didn't start next day. Nothing changed ( except AFM wiring; lengthen wires of 20 cm) First diag : no spark at all ( none of 4 cylinders ) I tried many things, including this : Testing CAS - working Testing Coils - internal resistance is 9.3k ohm for both - working No wiring problem between components and ecu ( 2*4 coils pins, ok. 4 CAS pins, ok ) 12v coming to coils 0v ( don't know how to say in english Also tested ECU led diag ... led never lighted up ! ( tested on a separate power AC, so the led was working ) My battery is ok, my starter is working. spark plugs are like 2k km old. 4 spark plugs at a time ? surely not No coils to test. 2 coils at a time ? surely not I thought of AFM, but car is supposed to start, even without it .. Any idea on what's going on ? I have no more idea on what to do ... Thanks guys ... U're my last hope |
#2 (permalink) |
Someone will help, be patient!
'94 Sepang blue project :: '95 flat black, HT | riced, JR45 '89 2WD, burgandy, Lariat F-150 | leveled w/ 31s |
#3 (permalink) |
Check all your grounds first.
My Build Thread 1993 Electronic Pearl Blue Miata- Brain built MS2,Stock 1.6 with a SR20 turbo on 14 psi, 3 inch downpipe to open dump, custom stainless steel tubular manifold, Rx7 460cc injectors, MTX-L wideband. Slam Thread ![]() |
#6 (permalink) |
Cr.net is addicting
Ok i double checked mine an i had 1 of the 2 red wires crossed . There should be 2 red wires going to the plug one of the wires is a shielded wire the other isn't . Make sure you have the solid red wire connected to the shielded one .
I'm still unsure if this is the cause of a NO start but it doesn't help . |
*Project* Now it has a name . |
